valk2128
« on: April 05, 2010, 04:37:43 PM » |
I purchased new Dunlop E3's back in late December 2009, call tire dealer and told them about the wobble a few days later. Recently had the chance to take the bike back to the Tire Dealer and they checked the tires, the rear tire had a bad high spot. I had them get me an Avon Cobra to replace the bad Dunlop, they got me a new tire and I paid $30.00 for the price difference between the 2 tires. If you need tires in GA, I would highly recommend Two Brothers in Lawrenceville GA.
So, this took care of the bad bounce I was getting from the rear.
I still have a wobble, that you can feel just rolling the bike down the driveway. Even my wife can feel it as I push her down the driveway.
I have replaced the front wheel bearings and I did re-torque the steering stem. I do not feel any indexing in the steering stem.
I replaced the standard shocks with Interstate shocks and replaced the shock bushings.
The odometer has 18,300 miles on it.
Any and all suggests / Ideas are welcome.
If you live in the Ga area, I would welcome your help.
Thanks.
« Last Edit: April 06, 2010, 02:49:43 AM by valk2128 »
mikeb
vrcc-29271
dansville mi by lansing mi
« Reply #1 on: April 05, 2010, 05:03:45 PM » |
time to put it on a cycle jack and hand spin the tires i wish ya were closer i would be glad to help ya ya need to jack it up and place a marker like a deepwell socket at the center and hand spin the tire and check both sides too and watch for run out while it spins at low speed
i dont care what you ride just ride mike & kari mivrcc capital city leader s.s.d.d.
« Reply #2 on: April 05, 2010, 05:31:32 PM » |
I trust you've checked tire pressures (46PSI on the rear). Shock bushings good? A low speed wobble is a new one. Swingarm bearings? Brake drag or warped brake rotor. You didn't say the mileage on the chassis.
« Reply #3 on: April 05, 2010, 05:36:59 PM » |
Front tire maybe? ???
Valker
Wahoo!!!!
Texas Panhandle
« Reply #4 on: April 05, 2010, 05:42:10 PM » |
Are the tires seated full on the wheels? That sounds just like a tire that is not fully seated.
RTaz
Oscoda, Michigan
« Reply #5 on: April 06, 2010, 04:24:35 AM » |
I don't know maybe check your shock bushings?
 RTaz
« Reply #6 on: April 06, 2010, 09:59:48 AM » |
Yup, it's the tire and not your imagination.
I've had the same problems from my E-3 front and adjusting the tire pressure helped some but not really much.
I think it is from a faulty manufacturing process.
The sidewall is not uniformly laid up which causes a density variation that manifests itself in a uneven rolling resistance and noticed by you as a wobble.
Pump up the tire to some unreasonable pressure and it will be more evident to your eyes and when riding.
A softer tire will hide some of the wobble but them it feels mushy.
Last Dunlop I will buy, I assure you!
valk2128
« Reply #7 on: April 06, 2010, 01:58:46 PM » |
I have ordered a new Avon Cobra and will be replacing the Dunlop (it has about 300 mile on it).
This is the last Dunlop tire I will ever buy.
I will provide an update once the Avon is on my Valkyrie.
Thanks, you guys are great.
