January 30, 2026, 08:12:41 PM *
Author Topic: worn clutch lever bushing (not typicaly one to replace)  (Read 2276 times)
upjeeper
« on: April 10, 2010, 03:19:49 PM »
I've got a lot of play in my clutch handle. So much so that it doesn't engage the clutch switch.
I've replaced the bushing (below part #2) but that doesn't seem to fix the problem. Is it common for the busing within the handle (#15) to wear out? I can't seem to press that small brass bushing out otherwise i could mic it.
greggh
OMAHA NE
« Reply #1 on: April 10, 2010, 05:44:07 PM »
I had the same problem with mine and I just bought a new lever and a #2 and all is well.
upjeeper
« Reply #2 on: April 10, 2010, 06:10:54 PM »
thanks, that's what i suspected. i couldn't press out that bushing insert so i figured the lever must be a maintenance item
« Reply #3 on: April 10, 2010, 09:51:26 PM »
Get a pair of Kuryakin wide blade levers. You won't regret it.
Tropic traveler
Silver Springs, Florida
« Reply #4 on: April 11, 2010, 09:04:51 AM »
Same here.
The stock handle is a fairly inexpensive item.  Cool
'13 F6B red for Kim
NITRO
Eau Claire, WI
« Reply #5 on: April 11, 2010, 02:56:09 PM »
+1! You can get the levers made for the 1800 Wing for about $40 shipped. They look fantastic and are adjustable.
When in doubt, ride.
« Reply #6 on: April 11, 2010, 05:14:26 PM »
Are the wing levers wider than the stock Valk ones?  Sort of like the Kury's?
Hay  Cool
MP
North Dakota
« Reply #7 on: April 12, 2010, 05:38:57 AM »
Yes.  I have them on both my Valks, and like them very much.  You do need to grind off one tab on the clutch side.  Takes about a minute.
MP
"Ridin' with Cycho"
