June 21, 2025, 05:34:39 PM *
Inzane 25
Author Topic: New handlebars - How to lengthen electricals???  (Read 3257 times)
Nico
El Diablo !!!
Chi-town Burbs
« on: March 13, 2009, 10:53:02 AM »
If you needed to lengthen the wires when adding new handlebars, how would you go about it?
Rewire the whole line?
Splice (solder) in an added length?
What say you???
Nico
DFragn
« Reply #1 on: March 13, 2009, 11:23:18 AM »
I soldered in extensions for my Tach & speedo when I relocated them to the bars. If I recall the tach had 17 wires and the speedo 4.
Since your talking about your switch controls I don't see why you couldn't solder in some extra length there also.
Black Heat Shrink Tubing is a good thing too.
Big IV
Iron Station, NC 28080
« Reply #2 on: March 13, 2009, 07:36:46 PM »
Black shrink wrap and double check which way you're routing as you do it.
"Ride Free Citizen!"
VRCCDS0176
chrise2469
Winnipeg Manitoba Canada
« Reply #3 on: March 13, 2009, 11:20:56 PM »
Splice and solder,  two tips-
 shrink wrap goes on  first
stagger your splices- there are a lot of wires and if you cut them at the same spot you will have a very thick cable in one place.
I did it last summer with 4 inches of extension.  I only needed to do the right side as I was able to reroute the left side without problems.
Hope this helps.
