January 30, 2026, 10:26:57 PM
PAIR VALVE ???
Topic: PAIR VALVE ??? (Read 2224 times)
Sonny
Holt, Mo.
PAIR VALVE ???
April 16, 2010, 03:31:40 PM »
Does anyone know what if any problems occur when the pair valve does not operate like it's supposed to? I hear a tickin sound that I had originaly thought was the valves needing adjusting.
Nope they are right on. It does how ever sound like it's coming from the center of the motor. Bike only has 40,000 miles not even broke in yet. Must be something simple. Also does it make any difference that it's a California bike? Just wondering? Heading from the midwest MO over to the Dragons tail area in few weeks tyring to be prepaired ahead of time.
What a great day, lets ride!
1999 Valkyrie Standard
2003 VTX, 1800C
Re: PAIR VALVE ???
April 16, 2010, 03:48:31 PM »
Well you found one of the problems but there are more the pair valve in itself is nothing but reed valves that allow the exhaust to suck in air. Now first reed valves and exhaust dont mix well they really dont seal the way there supposed to. The valve that lets air into the pair valve can go bad causing a vacuum leak. In some cases they can cause backfiring.
Re: PAIR VALVE ???
April 16, 2010, 03:49:20 PM »
Ticking is the pairs. From what I know its normal.
Re: PAIR VALVE ???
April 16, 2010, 04:00:54 PM »
check your exhaust header bolts, only 6 ft lbs to tighten. they do come loose.
Sonny
Holt, Mo.
Re: PAIR VALVE ???
April 16, 2010, 04:06:13 PM »
Thanks for the input. I have checked almost everything on the motor aside from taking it apart I can think of. But I have not taken the PAIR valve apart yet. The motor on both my Valk's has always been silent. This sound is realy irritating. If the reed valves are replaced what is the chance the noise will stop as well?
2003 VTX, 1800C
Dave Weaver
Seymour, IN
Re: PAIR VALVE ???
April 16, 2010, 04:25:27 PM »
Do a desmog and never worry about it again. Plenty of info in ShopTalk and archives about it. We'll even help talk ya through it.
Do unto others as you would have them do unto you.
Re: PAIR VALVE ???
Reply #6 on:
April 16, 2010, 06:28:00 PM »
Quote from: Dave Weaver on April 16, 2010, 04:25:27 PM
+1
