January 31, 2026, 01:27:50 AM *
Author Topic: HUH ....look what I found ....  (Read 3075 times)
Sodbuster
« on: May 02, 2010, 07:16:22 PM »
I was in the process of checkin on the condition of the rear splines that I hadn't done since I bought it last fall.  I decided to remove the rear pumpkin while the wheel was off and realized that the drive shaft came with it. So, just for giggles I took a flashlight and looked up inside the swingarm tube and noticed a long curly lookin object up by the u-joint. I used a long retracking jaw clamp tool and pulled it out and here is what I found (that's a 10mm wrench I layed next to it for comparison).  If you're familiar with machine shop you'll realize that curly object is the result of a drilling operation. Only thing I can think of is it's been there since it left the factory. It didn't appear to have wrecked anything.
Also, I found that the splines were OK but the drive flange pins were dry and the wheel bearings were shot ....bike has 23k miles .... glad I made the effort to check things out.
VRCC # 30938
« Reply #1 on: May 02, 2010, 08:06:24 PM »
Dude, your bike appears to have had a tape worm.  LOL
Sodbuster
« Reply #2 on: May 02, 2010, 10:11:43 PM »
 Grin hey .... maybe I'll get better gas mileage now that it's gone
VRCC # 30938
roboto65
Conroe,TX
« Reply #3 on: May 03, 2010, 05:01:21 AM »
 2funny 2funny 2funny
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
Ferris Leets
Catskill Mountains, N.Y.
« Reply #4 on: May 03, 2010, 05:51:21 AM »
I found about a tea cup full of chips when I took the oil pan off of my Guzzi.   I think they contributed to a premature rod bearing failure.
MNBill
Southern Minnesota
« Reply #5 on: May 03, 2010, 08:23:50 AM »
Could the spring used to hold the chrome driveshaft cover get sucked in the somehow??? A guess as that is what teh spring that holds mine on looks like
MNBill
SE Minnesota
Oldswimr
NE North Carolina
« Reply #6 on: May 03, 2010, 08:50:11 AM »
how hard are the bearings to replace? I'm about to check my splines, so I may as well be prepared..
"Yes, it's fast, no you can't ride it.."
« Reply #7 on: May 03, 2010, 09:53:28 AM »
The drive flange pins are suppose to be dry. No grease should be on them. Grease traps particles which grind away on the pins and bushings.
Sodbuster
« Reply #8 on: May 03, 2010, 05:43:06 PM »
I TOTALLY disagree .... the shop manual tells you to lube them, my reputable Honda dealer tells you to lube them with a good moly grease.  All the splines and drive pins will be getting a dose of Guarddog 525   cooldude
« Last Edit: May 03, 2010, 06:39:38 PM by Sodbuster » Logged
VRCC # 30938
lee
Northeast Tennessee
« Reply #9 on: May 03, 2010, 06:53:39 PM »
I just looked at the Service Manual Section 14 page 7 Final Driven Flange.
Please tell me where it says to lube the flange pins.  I can't find it.   Undecided
Time is not what is taken but what remains.
C. Drewry
Sodbuster
« Reply #10 on: May 03, 2010, 07:10:55 PM »
I'm looking at Clymer manual .... section 11, page 370, On rear hub installation, item 5 .... "Apply a light coating of molybdenum disulfide grease to the driven flange pins (figure 33)"
Also, Carl Kulow's "Valkyrie Maintenance Guide" mentions to do the same
Click HERE and also in ShopTalk.  I spent a good half hour talking to a Honda shop manager at a reputable dealer about it one day and he said the same.
On Goldwing forums it talks about lubing the 6 pin flange but not the 5 pin flange .... go figure.
VRCC # 30938
Printer Mike
Eatonton, Georgia
« Reply #11 on: May 03, 2010, 09:24:24 PM »
Wooooh..... For a sec. thought you found the wrench in there!!! 2funny
Never give up!
RP#62
Gilbert, AZ
« Reply #12 on: May 04, 2010, 06:00:03 AM »
You can lube them if you want, but the next time you go to take the flange out of the wheel you'll understand what Sandy is talking about.  The shoulder on the pins will wear a matching shoulder on the ID of the bushings which will make it harder to get them apart.  If anything you can use a dry film lubricant or put some moly grease on them then wipe every last bit of it off.  There will be enough remaining in the pores to adequately lube them.  If you use a wet lube though, they'll wear as described.
-RP
