January 28, 2026, 08:15:49 AM *
Author Topic: Final drive weep holes?  (Read 5786 times)
« on: March 15, 2009, 07:18:58 AM »
Have mine off but do not see the holes. Where are they at?  Evil
Mr.BubblesVRCCDS0008
« Reply #1 on: March 15, 2009, 08:04:35 AM »
If you remove the driveshaft from the coupler you should see two holes in the bottom by the nut that holds the coupler to the final drive.
Bagger John - #3785
« Reply #2 on: March 15, 2009, 08:04:49 AM »
Underneath that little chromed cap that sits on top of the unit...
ETA - that's the "vent" hole. Not sure if this is what you're after.
Warlock
Magnolia, Ms
« Reply #3 on: March 15, 2009, 08:11:34 AM »
Pull your driveshaft out of the pinion joint. The holes are probabbly covered up with grease. Clean the pinion joint real good and you will see the two little holes. The red straw that fits into the cleaner can will fit thru the holes. This is how little the holes are. The holes you want are not under the chrome breather cap. I use brake cleaner to clean everthing up. I even spray it into the pumkin after I clean the pinion joint and make sure the holes are open. Hope this helps.
David
« Reply #4 on: March 15, 2009, 12:19:48 PM »
Whether you find the holes or not, be sure to grease the splines with a good moly Grease. That's 2 % minimum moly content. Valvoline makes a 3% semi synthetic grease. I got a can at Autozone, but it's pretty common at other auto stores.
« Reply #5 on: March 17, 2009, 06:54:11 PM »
David
I forgot I posted this till tonight after I put the rear end back on!  Grin I pulled the drive shaft out and it was rusty in the center of a 'nut' looking thing. I did poke it with a needle to clean it. It was all rusty and dry in there. 1st time its been pulled in 47,000 miles.  Evil
JeffL
Maine
« Reply #6 on: March 18, 2009, 05:50:36 AM »
Found mine all rusty and dry last winter.
99 Valk
07 V-Strom 1000
Daniel Meyer
The State of confusion.
« Reply #7 on: March 18, 2009, 05:52:50 AM »
I hope you replaced that shaft and pinion cup...that one's gone!
CUAgain,
Daniel Meyer
JeffL
Maine
« Reply #8 on: March 18, 2009, 02:31:08 PM »
[/quote]
[/quote]
Nope, I just took the picture and put it all back together......   Grin
Sorry, yes I did replace the shaft and cup.  Smiley  Found it was missing #35 on the fiche when I disassembled it.  Not sure if that was the entire reason for the problem or not.   99 Std w/ about 47k.
99 Valk
07 V-Strom 1000
« Reply #9 on: March 18, 2009, 07:33:52 PM »
Holy cow!  Shocked Mine wasnt that bad. I still had grease around the splines. Wow again!
lee
Northeast Tennessee
« Reply #10 on: March 18, 2009, 07:41:50 PM »
Number 35 is an O-ring that goes on the outside of number 10.
It did not cause your problem.
Time is not what is taken but what remains.
C. Drewry
