January 31, 2026, 01:27:44 AM *
Author Topic: How can I charge my MP3 Player on my bike...Suggestions?  (Read 1997 times)
poman
Panama City, Fl
« on: May 04, 2010, 09:11:46 AM »
I am in the process of putting together a sound system for my 98 tourer. I need some sort of USB port for charging my MP3 player while riding without adding a lot of extra junk to the bike. Ideally it would be a female USB connector with a hot and ground comming off the back for me to connect to a battery. simple and small. but I havent found anything like that.
"Pyle" is the only vendor that claims they sell one with their system but wont return calls. (that fact alone tells me I wont buy their speaker/amp system.)
Thanks for your time guys.
Poman clear
roboto65
Conroe,TX
« Reply #1 on: May 04, 2010, 09:18:04 AM »
Well a USB port is 5 volts so you will have to regulate the 12 volts down. How you do that is the other thing there are devices that do that at least in R/C planes that I fly LOL we have Voltage regulators for our battery packs so I have a small one that could be wired to a female USB port which I have been thinking about doing just have not done it Yet LOL
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
Joe Hummer
Arnold, MO
« Reply #2 on: May 04, 2010, 09:19:51 AM »
I have a power outlet mounted on the triple trees under the fairing.  They make USB cigarette lighter adapters that will plug into the power outlet.  The outlet I have I got at Wal-mart (in the automotive electrical section).  It is sealed and has a hinged cover on it.  I wired it through a relay so it switches off when the bike is off.
Joe
1999 Valkyrie Interstate
« Reply #3 on: May 04, 2010, 09:19:59 AM »
I guess there is a charger that uses a cig adapter. Cut the plug off and wire it direct. Or instal a cig and plug it in there. Lucky for me I have a mp3 that uses AAA batteries. Got it in 06. Took a dump but found another on ebay. I tried to find a updated version but didnt like the fact I had to charge it. Wal-mart has the charger.
Bob E.
Canonsburg, PA
« Reply #4 on: May 04, 2010, 11:49:01 AM »
Joe
I did this on mine for my ipod...except my power outlet is under the seat.
« Reply #5 on: May 04, 2010, 02:27:19 PM »
jcw 29 bux. Fused off my fuse block I installed.   hoser
PhredValk
Edmonton, Alberta, Canada
« Reply #6 on: May 05, 2010, 10:30:34 PM »
Canadian Tire up here sells a block with 2 cig lighter holes and a USB connector, about 4x4". Used it on my GL1100 to power an iPod Touch. As long as the circuit is isolated from the engine power it works fine (I used an Inverter). Someone like JC Whitney must sell something like this.
Fred.
VRCCDS0237
