January 31, 2026, 02:47:42 AM *
Author Topic: will vtx 1800 risers fit a Valk?  (Read 2496 times)
laserpat
Cedar Park, Texas
« on: May 06, 2010, 07:32:56 PM »
Anybody know? some came up on craig's list. tia
Disco
Republic of Texas
« Reply #1 on: May 06, 2010, 08:21:18 PM »
Hey Pat, I'm almost certain they all will.  I just checked all the '03 models.  The key to being sure is if the flange nut under the upper triple clamp that attaches to the bottom of the riser (Handlebar & Top Bridge fiche part Cool is 12mm like the Valkyrie's
What helped me in my recent handlebar / riser change is the riser adapter kit from Baron Customizing.  It's 12mm on the bottom and 1/2" on top and allows use of all the HD-style risers out there WITHOUT drilling the upper triple clamp.  About $20.00.  If you go that route, the HD-style one-piece top clamps are on 3.5" centers and won't work on the Valkyrie.  The Valkyrie risers are on 100mm centers - about 4" - and require individual riser top clamps if you use HD-style risers.
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
Gunslinger
Brian Huntzinger, EMT-P
Wamego, KS
« Reply #2 on: May 06, 2010, 10:25:45 PM »
Anyone know the rise and pullback of the VTX risers?
VRCC#   26468
VRCCDS# 0228
"Some learn by listening, Others learn by watching...
The rest of us have to pee on the electric fence ourselves"
laserpat
Cedar Park, Texas
« Reply #3 on: May 07, 2010, 05:39:10 AM »
It looks like 1.5" pullback with 3/4 " rise
« Reply #4 on: May 07, 2010, 05:49:08 AM »
Maybe this will help........A friend of mine wanted longer risers on her VTX so we got some Valkyrie risers.....they fit ok, but the theaded stud that goes through the tree is shorter on the Valkyrie risers.  I almost didnt mount them for that reason, but I got almost the entire nut engaged.......the end of the shaft was just shy of extending through the nut but it tightended up fine.  So going the other way you will have excess bolt and the risers will move the bars forward and down a tad, but otherwise will fit fine
PAVALKER
Pittsburgh, Pa
« Reply #5 on: May 07, 2010, 06:25:02 AM »
They will fit.... but the risers size and pull back differ depending on the model of the VTX.   I had put Rivco Risers on my VTX 1800 R (the stock R risers are very short).  My brother who has a VTX 1800C (which are longer and more pull back than the Rivcos) replaced his Risers and I put his 1800C Risers on my 1800R and took my Rivco Risers and put them on my Valk I/S.   I think if you got stock 1800C Risers they would fit fine on the Valk without any cable mods.  However, I can't guarantee it.... it depends on your model Valk.   I know my Rivco Risers are slightly shorter than the stock 1800C Risers.   And, being they are squared, there might be a little hang over on a corner where it sits on the top clamp.
John
Mr.BubblesVRCCDS0008
« Reply #6 on: May 07, 2010, 08:56:27 AM »
Pat I'm running risers from a 2002 VTX1800C on my interstate as we speak. They're about as tall and about as much pullback as you can get away with stock cables. You can run the stock valkyrie top clamp but the corners of the riser will not be quite covered all the way. I have an xm radio velcroed to mine so it doesn't bother me. If you get the vtx clamp or an aftermarket clampfor a vtx they will be covered. cooldude
« Reply #7 on: May 07, 2010, 09:04:52 AM »
A good standard to follow is;
The minimum thread protrusion for male threaded fasteners is one full thread beyond the face of the nut or plastic insert of self locking nuts.
