January 31, 2026, 07:33:03 AM *
Author Topic: What's The Difference, Avon Tires  (Read 2959 times)
Red Diamond
Beaumont, Texas
« on: May 07, 2010, 10:35:33 PM »
Cobra, Venom, Venom-R. I ordered two Avon Cobras, just curious as to the difference. I also may try the no balance  trick for a while, just thinking. Two tires, $313.98-$20.00 (CC20)=$293.98. Will apply for the $50.00 after receiving tires.
« Last Edit: May 07, 2010, 10:38:57 PM by 99 Red Diamond » Logged
DFragn
« Reply #1 on: May 08, 2010, 05:43:24 AM »
If I'm right the Cobra's are the discontinued line. And if that's the case I would check the date code on the sidewall. 4-digit code includes the production week and 2-digit year. If they're any where near 5 years old I personally wouldn't install them.
Balance, if you mount and balance them yourself you may get lucky with locating the rim heavy spot and matching the tires light spot. Both of my rims heavy spots are 8 - 10' from the valve. My experience is the odds of not requiring balance weight is about 15%. Not enough to just throw them on and hope for the best.
six2go #152
Ft. Wayne, IN
« Reply #2 on: May 08, 2010, 06:24:38 AM »
"If I'm right the Cobra's are the discontinued line."  Nope! Cobras replaced the Venoms.
DFragn
« Reply #3 on: May 08, 2010, 07:11:28 AM »
Thanks. Haven't bought Avons in awhile and my rememberer slipped again.
Wildman
« Reply #4 on: May 08, 2010, 07:51:51 AM »
I put a pair of Cobra on last year.
I ran several sets of Venoms before that.
I got a flat on the rear tire.
While slowing down the tire de-beaded.
The bike wanted to go left (across the on comming lane).
I could have banked it over to correct but felt that that would have put the rim on the pavement and the bike could have slid out from under me.
There was a pick up truck a good distance down the road in the on-comming lane, but I had eye contact with the driver, and decided to slow down across his lane and stop on the far sile shoulder.
At least I knew the pickup driver was knew I was there. He aws looking at me and comming up over his streeing wheel with a (what are you crazy kind of look on his face). Everthing came out OK.
I wrote about it last year on this board and another rider had the same experieince on the Cobras while leading a group of bikes. He was taken across lanes also, due to de-beading of the tire.
Has anyone else had this problem?
I immedeately changed to a set of E3s
I lke the performance of the Avons but not if a flat may cost me my life.
I have a few flat rears and one flat front and always been able to control the bike even ride it at slow speed to get it to where I could fix it.
The Avon flat was uncontrolable even at 1 mile / hour
Please respond if you have had a Cobra flat, espescially a de-beading .
Is this an annomily or are the Cobras safe to use?
roboto65
Conroe,TX
« Reply #5 on: May 08, 2010, 07:55:59 AM »
I am not sure which is on the back of my fatgirl but it an Avon and it had a nail in it and limped it home 30 miles well it ran fine till about a mile or so from the house and it went low but albeit a little wobbley at low speeds the bead stayed on.
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
Wildman
« Reply #6 on: May 08, 2010, 08:29:17 AM »
Roboto 65
Was it a Venom or a Cobra?
Farther
Quimper Peninsula, WA
« Reply #7 on: May 08, 2010, 09:10:59 AM »
I think the Cobras are the newer Avon radials, the Venom are bias and the Venom R is a radial.
~Farther
Tropic traveler
Silver Springs, Florida
« Reply #8 on: May 08, 2010, 05:34:57 PM »
Had a slow {if you can call 15 or so seconds slow} rear air loss due to nail at 70 mph with a Venom R. I was able to coast to a stop with no de-beading {Thank you Lord!}. Plugged it & continued on our trip thanks to my handy dandy Wal-Mart 12V compressor & rope plug kit. Of course ordered a new Avon the next day.
I have had good performance from both the Avon Venom-R & the Cobras that replaced them.
Not such good luck avoiding nails in the rear tire only!  tickedoff
'13 F6B red for Kim
Red Diamond
Beaumont, Texas
« Reply #9 on: May 08, 2010, 06:39:06 PM »
Thanks Guys, I was beginning to run short of breath with that first post. LOL
Red Diamond
Beaumont, Texas
« Reply #10 on: June 07, 2010, 08:18:08 AM »
I received a letter from Avon stating that my rebate would be sent in the form of a debit card, which would bring the price of the two tires to $243.00.
DFragn
« Reply #11 on: June 07, 2010, 01:08:40 PM »
Sorry, that's why I said "if I'm right". I was sensing a brain-fart in process. I should learn to trust my instincts.
MNBill
Southern Minnesota
« Reply #12 on: June 08, 2010, 06:21:51 AM »
The Avon Debit card is good for PURCHASES ONLY. In the past I have taken those rebate cards to the credit union for cash but that does not work with the Avon card. They charged me 1.50 to ask them why the card did not work too.
MNBill
SE Minnesota
Cliff
Manchester, NH
« Reply #13 on: June 08, 2010, 07:36:28 AM »
And only if the purchase amount is equal to or less than balance on the card,,, you can't use it to do a partial pay.  I ended up using it for gas for the Valkyrie, but had to do prepay using this card.  Still a $50 rebate just some hoops to jump through.
VRCC # 29680
