January 31, 2026, 05:48:51 AM *
Author Topic: Diesel Oil  (Read 2768 times)
V-SIX DS#121
Western NC
« on: May 23, 2010, 03:47:20 PM »
  I know this has been mentioned before, but why use Diesel Oil ? ???
« Reply #1 on: May 23, 2010, 04:04:54 PM »
Hmmm.....good question.  cooldude I know my hd bud uses it. Most of the time he empties it out of the dump trucks oil right into his bike.  Undecided
Farther
Quimper Peninsula, WA
« Reply #2 on: May 23, 2010, 04:56:35 PM »
It's cheap compared to motorcycle oil and it meets Honda specs.
~Farther
Mildew
Live, Not Just Exist
Auburn, Ga
« Reply #3 on: May 23, 2010, 06:39:39 PM »
It's a heavy duty oil that meets diesel specs. Not just for diesels.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #4 on: May 23, 2010, 06:52:05 PM »
I am currently running Amsoil Diesel oil, synthetic....then again, I am not known for consistency in my oil choices. cooldude
John U.
Southern Delaware
« Reply #5 on: May 23, 2010, 08:29:46 PM »
Diesel oil doesn't contain the friction modifyers that mess up a wet clutch.
« Reply #6 on: May 24, 2010, 03:04:20 AM »
I'm wondering if anyone is using the Rotella 15-40 conventional vs. the synthetic 5-40 ??
Warlock
Magnolia, Ms
« Reply #7 on: May 24, 2010, 04:24:27 AM »
Planning on switching to that next oil change.
David
CamTom12
VA
« Reply #8 on: May 24, 2010, 05:14:34 AM »
I ran it for quite some time in both of my bikes but switched to Delo 15w-40 this time around (only because I switched to Delo for the truck. The bikes were running fine on Rotella).
« Reply #9 on: May 24, 2010, 05:41:30 AM »
better high shear oil than others, also high anti-foaming additives, the trans gears can aerate oil.
www.bobistheoilguy.com
X Ring
VRCC #27389, VRCCDS #204
« Reply #10 on: May 24, 2010, 06:28:43 AM »
This.
Marty
Earl in Pensacola
« Reply #11 on: May 24, 2010, 09:49:43 AM »
I've been using Rotella 15/40 non-syn for about 8 to 10 years in a '97 Tourer that is now at 221K, has the OEM clutch, never had the engine opened, except for valve adj's about every 30 or 40K and I change the oil and filter at about 4500 miles.
