January 31, 2026, 07:32:19 AM
Electrical Snafu
Topic: Electrical Snafu (Read 1870 times)
PJR
Electrical Snafu
May 23, 2010, 04:48:32 PM »
I just installed a sidecar on my 2000 I/S this week. Finished this afternoon, and went for a shakedown run. Did a couple laps at the school parking lot; all seemed good. So, I hit the interstate, cruised about 6 miles to next exit, stopped, shut bike off to check tires and such. Got back on the bike and started up country road. Looked at speedo, nothing; no tach, no fuel gauge, no turn signals.
So stopped the bike again, left it running to check other things; head lights working, no tail lights, no brake lights, no radio volume, no neutral light. Anybody got any suggestions? Could not find any blown fuses. TIA
Paul, upstate NY
Valker
Wahoo!!!!
Texas Panhandle
Re: Electrical Snafu
May 23, 2010, 06:57:53 PM »
If it's an Interstate, that is usually the first sign of a battery going out.
X Ring
VRCC #27389, VRCCDS #204
May 24, 2010, 06:36:47 AM »
I had a problem once similar to yours. Nothing on the back worked. Checked everything and could not find the problem. Finally just on a hunch, I stuck a new fuse in and everything worked. There was nothing I could find wrong with the old one but it must have been on the way out.
Marty
1FAST6
Sanford, NC
May 24, 2010, 10:31:57 AM »
You might have pinched a wire putting it together. I'd start in the fuse box and trace from there.
May 24, 2010, 12:44:23 PM »
Did you have the front tire off? It is possible to mount the sensor wrong and end up with no speedo. Tach should work though. Don't ask me how I know this.
hoser
PJR
May 24, 2010, 06:37:52 PM »
Marty, I followed your lead, replaced all the fuses though, cured the problem! All the fuses looked good, but I went ahead and replaced them, maybe just corrosion around the blades. Anyways, thanks for all the input guys.! Paul
