January 31, 2026, 05:50:04 AM
Idle adust knob sticking/hard to turn.
Topic: Idle adust knob sticking/hard to turn. (Read 1829 times)
Argon0639
Maryland
May 23, 2010, 05:18:11 PM »
So recently my idle adjustment has become very hard to turn...very!
Any suggestions to rectify this?
Pete
Re: Idle adust knob sticking/hard to turn.
May 23, 2010, 06:29:26 PM »
A little liquid wrench should help, if it is water, soap, dirt, rust residue causing the issue.
Thunderbolt
Worthington Springs FL.
Twist the throttle a little
May 23, 2010, 08:15:13 PM »
if you are attempting to increase engine speed. It could need lubrication also.
valk2128
Suwanee, GA
May 24, 2010, 03:36:03 PM »
Had this same kind of problem awhile ago, wound up the adjustment screw inside the knob was bent. Replaced it and no more problems.
joefromperry
Perry, OH
May 25, 2010, 05:39:34 AM »
Same problem here last year, and we found the screw inside the throttle adjustment knob was bent. Took it apart and replaced it; all is fine now.
2000 Honda Valkyrie Interstate Silver/Blue
2002 Honda Shadow ACE Deluxe
1972 Honda CL350K4 Scrambler
2008 Ural Patrol
1987 Honda Rebel 450
