November 19, 2025, 12:06:25 AM *
Author Topic: F break light  (Read 5161 times)
Kidd
Sedona
« on: March 18, 2009, 10:35:11 PM »
Using the front break , the  break light should come on, right  ?
Mine doesn't
Mr.BubblesVRCCDS0008
« Reply #1 on: March 18, 2009, 11:01:33 PM »
Try cleaning the contacts where the wires plug on to the switch. Most likely  just dirt. Check to see if you can hear a click when lever is pulled.  You can also try spraying some contact cleaner in the switch its self. Switch is cheap if it is the problem.
Kidd
Sedona
« Reply #2 on: March 18, 2009, 11:05:57 PM »
Soooooooooooooooo , the light should come on , then
« Reply #3 on: March 19, 2009, 01:37:03 AM »
Yes it should come on ( rear brake light ) when front brake lever is pulled.
Big IV
Iron Station, NC 28080
« Reply #4 on: March 19, 2009, 03:59:13 AM »
also comes on with the rear brake is pushed down...in a pinch you could *ahem* cover the pedal and the lever at your inspection. When they say, "rear brake" hit them both.  When they say, "front break," hit them both.  Gets you past inspection so that you can fix it later.
"Ride Free Citizen!"
VRCCDS0176
Kingbee
VRCC# 576
Northern Illinois
« Reply #5 on: March 19, 2009, 07:06:47 AM »
Those switches do fail, but they're cheap.
1999 Interstate
2000 Interstate
2004 Rune
