JScott
« on: June 12, 2010, 06:18:35 PM » |
This is a 2000 standard. The yellow light on the headlight came on , but it was on continuous. When I checked, the left turn lights were stuck on. But on steady not blinking. When I turn on the right side it works correctly, and shuts off when I put the turn switch in the center position. But, the left side stays on even then. I swapped turn switches no change. I swapped relay switches no change. I disconnected the relay switch, removed both front and rear turn lights and the yellow light on the headlight still is on . So is there anyone who's had the same problem, or knows where I need to look next ?
Moonshot_1
« Reply #1 on: June 12, 2010, 06:53:01 PM » |
I can't say if this works the same way, but when it has happened in my car or truck it means that one of the bulbs is burned out on the side that is is no longer blinking. It just stays on steady.
Mike Luken
Cherokee, Ia. Former Iowa Patriot Guard Ride Captain
Red Diamond
« Reply #3 on: June 12, 2010, 09:30:12 PM » |
Your turn signal lights on the front should burn continously, just like the run light portion of your tail light. If it does not blink when you turn it on, you have a turn signal element burnt out. If there is no light on the right side when the signal is off, you have a run light element burnt out. Change both bulbs, they should both burn all the time. The turn signals on the rear do not burn all the time and are used only for signals unless they are wired for run/turn/stop lights.
JScott
« Reply #4 on: June 12, 2010, 11:16:10 PM » |
O. K . ON the left side, the front running light AND the front turn light elements are both on + the rear element . Even when the right side is blinking . Even when the handle bar switch is in the center/off position. On this bike , IF I remove 1 bulb or burn out a bulb that side just blinks/flashes faster. When I turn the bike on , both the front running lights come on + the front and rear turn light elements NO BLINKING.
« Reply #5 on: June 13, 2010, 05:00:25 AM » |
R U saying the rear turn signal bulbs light, when you hit that signal?
If so change the front bulbs, both of them......
If ya don't you will be back here again in a few days.
Front bulb is a dual filament, rear is single.
Jack B
« Reply #6 on: June 13, 2010, 05:18:15 AM » |
If it's not the blub clean the grease in the handlebar housing
Let’s RIDE
flatsixlover
« Reply #7 on: June 13, 2010, 05:32:15 AM » |
 +1 on cleaning the switch housing. Had a similar problem with turnsignals not behaving properly, but after cleaning the switch everything was good. FlatSixLover
JScott
« Reply #8 on: June 13, 2010, 06:51:52 AM » |
AS I said in the beginning, I've SWAPPED OUT THE HANDLE BAR SWITCH AND THE TURN SIGNAL RELAY. [used parts from a different valk ] The problem didn't change. When I turn the bike on, BOTH the filaments on the front left turn light come, and the rear turn light comes on. This stays that way even when I turn on the right turn signal.
N8171S
« Reply #9 on: June 13, 2010, 06:58:41 AM » |
When was the last time you changed the blinker fluid?
Scott from FL, now in Maine
« Reply #10 on: June 13, 2010, 09:23:02 AM » |
Did you check the ground strength on left side both front and back? When you have a loss of ground, the system will seek a ground and often finds it thru the second filament on the bulb. This can cause all the filaments to light up.
JScott
« Reply #11 on: June 13, 2010, 09:48:09 AM » |
OMG!! That was it, but it took me awhile to figure out if it needed Dot 3 or Dot 4 fluid!!
JScott
« Reply #12 on: June 13, 2010, 10:06:34 AM » |
Found the problem. Part of the wire harness under the rear fender had come out of the holder just enough to get rubbed by the tire when I bottomed out on a bad pothole. That caused a short from the taillight wire to the left turn wire. Thanks to everyone that responded.
tank_post142
« Reply #13 on: June 13, 2010, 10:15:30 AM » |
excellent troubleshooting!!
I got a rock  VRCCDS0246
Old Geezer Richard
« Reply #15 on: June 13, 2010, 08:19:19 PM » |
 Hey jScott , don't let them other guys BS ya over dot 3 or dot 4 ... I use dot 3/4 myself and nary a problem  ... just kidding , glad to see you found the problem .. the simplest thing will stop ya dead in the water that I've learned .... ride safe
If you don't care where you're going, then you ain't lost , Murphy's Law because wherever you are going to , it ain't going nowhere .... San Antonio,Tx.
