March 17, 2026, 08:08:48 AM *
Author Topic: Excessive gas consumption " plz help"  (Read 2384 times)
galleto
Unless you ride the BEAST,you wouldn´t understand
Irapuato, Gto " Mexico "
« on: June 13, 2010, 03:57:09 PM »
Buddies
Need urgent help, checking owners manual and browsing on the web I realized that valkyrie average Per galon is 33 to 36 depending of speed
but my bike is giving me ridiculous 9 miles/gl and full thank 42 to 45 mpg.
Plz assist me indicating what to do or what to check , I am really frustraded gas in México is 2.4 usd Per. Galón
All recomendation will be highly apreciatted
“ Dream as if you will live forever… Live as if you will die tomorrow "
Jess Tolbirt
White Bluff, Tn.
« Reply #1 on: June 13, 2010, 04:05:30 PM »
i think we have a language problem here...
36 miles per gallon is about right..
now,, are you getting 9 miles per gallon or 42 miles per gallon?
if you are getting 42 then just go ride and enjoy it...
Valkyrie member # 23084
« Reply #2 on: June 13, 2010, 04:26:13 PM »
I think what he's saying is he's getting 9 MPG, and getting 42 miles or so per tank, if I'm reading that right?
galleto - Just to make sure we're understanding you, how many miles do you get out of a full tank of gas?
Apenas para cerciorarse de que el entendimiento que estamos, ¿cuántas millas Qué se obtiene de un tanque lleno de gasolina?
(Disclaimer, hablo muy poco español, me engañó y utilizó un traductor de la computadora)
Super Santa
VRCC #27029
Houston, Texas
« Reply #3 on: June 13, 2010, 04:35:22 PM »
Then too could he be using liters in place of gallons?  Kilometers in place of miles?
Need to compare apples with apples.
galleto
« Reply #4 on: June 13, 2010, 04:58:24 PM »
Thanks every body for attending this post
what I'm saying is my valk is poorly giving 9 to 10 mpg or around 45 mpg per tank
sorry if i am confusing you
thanks
MP
North Dakota
« Reply #5 on: June 13, 2010, 04:59:32 PM »
Never heard of anything that bad.  Do not know.
Is the fuel line connected to the carbs, or just dumping on the ground?  LOL   Evil
MP
"Ridin' with Cycho"
Daniel Meyer
The State of confusion.
« Reply #6 on: June 13, 2010, 05:16:24 PM »
I would expect youhave a bad petcock...and it is letting gas down the vacuum line into the #6 cylinder...
Other possibilities...leaks...at the petcock, or perhaps a pinhole in the vent line (inside the tank) and fuel is leaking out the overflow hose...
Stuck carb floats along with a bad petcock...fuel is leaking past and flooding the cylinders...
Anyway, I'd start with the petcock...
CUAgain,
Daniel Meyer
big turkey
« Reply #7 on: June 13, 2010, 05:36:54 PM »
How is your bike performing?
Any issues there?
Do you smell a gas odor as you ride?
Could some of your buddies be playing a Trick on you.
Does your kid have a go cart and using Daddies Gas.
Is it or has it always been this bad/
If not when did it start happening?
WhAT COLOR IS YOUR BIKE.
KIDDING ABOUT THE COLOR.
Need some more info.
Is your choke or enrichener lever in the down position?
Is your cable broke to your choke. or become unattached.
Big Al
alph
Eau Claire, WI.
« Reply #8 on: June 13, 2010, 05:45:02 PM »
the first thing i usually check is the air filter.  i monitor my gas milage regularly, anytime it dips below 30mpg, and it stays that way, i'll check the air filter.  also, try a different gas station!  believe me (and most people don't) where you buy your gas, and the grade of gas, makes a difference on your milage.
good luck!  let us know what you find out.
Al.
Bob E.
Canonsburg, PA
« Reply #9 on: June 13, 2010, 05:47:21 PM »
I had an old Kawasaki that had a float stick open and gas would just run out of the overflow tube.  Maybe this is happening.  I can't think of any other way that a Valk could go through gas that fast unless it is dumping on the ground.
« Reply #10 on: June 13, 2010, 06:01:12 PM »
Did we ever establish if we are talking gallons and miles?
Or liters and kilometers.
I came across South Dakota  into a head wind, pulling a loaded trailer in the century digits and still got 17 MPG.
Was trying to outrun a Monsoon.  It caught me at the SD/MN line.
big turkey
« Reply #11 on: June 13, 2010, 06:06:09 PM »
I heard a guy mention one time that he bought a Valk and it had a rats nest in the air fliter area.
But 9-10 mpg is like unreal and the thing is obviously still running.
You got me brother.
Big Al
galleto
« Reply #12 on: June 13, 2010, 06:21:12 PM »
thanks RJ
the numbers I'm providing is miles / galons , and yes its ridiculous but is what I am getting
regards
galleto
« Reply #13 on: June 13, 2010, 06:31:34 PM »
in terms of speed its ok , but some times when I'm riding i feel like the bike is choking gas ( like if thd gas is not burning properly
Any issues there?
Yes I can perceive a lightly gas odor
Don't think so they are always kidding but this is no the case
No kids
Big Al
big turkey
« Reply #14 on: June 13, 2010, 06:38:56 PM »
Man this VRCC thing is really a International Thing.
Mexico
Canada
England
France
Sweden
Germany
Austrailia
USA
BigAL
highcountry
Parker, CO
« Reply #15 on: June 13, 2010, 06:47:47 PM »
Your MPG is so bad you would think that raw gas would be running out of the exhaust or leaking on the ground.  Do you smell gas?
If you haven't already done it, check the spark plugs and make sure that they are the right ones properly gapped.  Also, pull the tank and check the air filter.  But it still sounds like you have a leak which is very dangerous.
Another question - - did your bike just start having this problem or has it always had the problem?
Good luck and buenos dias.
alph
Eau Claire, WI.
« Reply #16 on: June 13, 2010, 09:44:45 PM »
does the bike run okay?  does it sputter baddly and not have good power?
do you park your cycle outside?  could someone be stealing fuel from you?  i would put a trail camera up and see if you catch anyone!!
New Haven, Indiana
« Reply #17 on: June 14, 2010, 03:15:46 AM »
I'm with Daniel.  If the Valk cranks hard in the morning and there's a smell of gas or gas coming out of the muffler, it would be a petcock problem involving #6 cylinder and maybe eventually a hydraulic lock.  Not good. Not enough info though and too many variables.
galleto
« Reply #18 on: June 16, 2010, 08:11:28 PM »
Thanks everybody for your comments and contributions ,I'll send my valk with the technician obviously all points suggested by all of you
hope this will help to correct my bike condition
Regards and keep driving safety
highcountry
Parker, CO
« Reply #19 on: June 16, 2010, 08:23:26 PM »
Let us know the outcome.
Wingman
« Reply #20 on: June 16, 2010, 08:49:41 PM »
I have another question.
Do you have black smoke coming out of the exhaust? A petcock isn't doing this unassisted, you may, as has been suggested, be leaking back through the vacuum line to # 6 cylinder, but there is a chance of hydro lock if this is happening. If you have a float sticking open in any of the SIX carburetors, it will be literally pouring the coals to one of the six cylinders and wasting fuel. Other than an out right leak, that's all that comes to mind.
Just to recap; if you have black smoke coming out of your exhaust, you are loading one or more of your cylinders and wasting fuel.
I would replace all rubber hoses, change the plugs (look for black ones) and do a compression test to make sure your engine is healthy. Be sure to have your throttle plate wide open when doing this test, you are looking for greater than 150 PSIG, (160 - 170 is very good).
Good luck with this.
