March 17, 2026, 11:13:14 AM *
Author Topic: Interstate risers  (Read 1110 times)
redbaron
« on: June 21, 2010, 09:30:46 AM »
Anyone out there replaced their risers on an interstate? I'm looking for risers with between 1 to 2 inches lift and about the same in pullback. Only thing is there isn't allot of room between the risers and the front fairing/dash on the interstate and a riser that is too straight will be in contact with the dash pod.
I see suppliers with risers that say they are for Valkyries, but the standard and tourer do not have the fairing obstructions. Can anyone recommend a riser that will work?
Gary
JimL
Naples,FL
« Reply #1 on: June 21, 2010, 09:41:52 AM »
These are what I use (and many other folks on this forum).  I have been extremely pleased with mine.
http://www.hondadirectlineofshadyside.com/stores/product.asp?pid=519&str=2&ID=415042359
DavRed
Buckeye AZ
Phoenix AZ
« Reply #2 on: June 21, 2010, 10:01:39 AM »
This should give you an idea.
http://www.timskelton.com/valkyrie/how_to/risers.htm
I use the HD Deuce on my Interstate.
Had to make some new bumpers between the Riser and Dash. I just got some black rubber things from the hardware store.
I have had them 2 years and Love riding with my elbows a little bent...
I am a little short I guess. 5'7"... These took care of that problem for me.
« Reply #3 on: June 21, 2010, 10:32:20 AM »
I use the HD Deuce risers as well (Interstate).
Two easy modifications were necessary:
1) Drill out the mounting holes to 1/2"; this requires very little drilling.  Stock risers still work after drilling.
2) Reroute cables to the inside of the tree.
Both mods are pretty simple (after all, if a girl can do it.... Wink )
You might have had to get longer bolts... can't quite remember (it's been awhile).
I used the LaMonster risers before switching to deuce, they work fine, but the deuce have quite a bit more rise and pullback.
« Last Edit: March 22, 2023, 06:03:50 PM by f6gal » Logged
