January 28, 2026, 09:54:05 AM *
Author Topic: turn signals going slower?  (Read 3445 times)
Fajack
« on: March 20, 2009, 03:13:51 PM »
What is the type of cleaner/grease to clean the turn signal switch.  My signals take 20 seconds to come on
John U.
Southern Delaware
« Reply #1 on: March 20, 2009, 03:29:44 PM »
The right way to do it is to take it apart and clean the old grease and apply new dielectric grease.
The easy way is to spray some electronic cleaner like tuner cleaner from radio shack. I used a product called Corrosion X . You can get the little red tube into the swtch where the left/right arm comes out. Have a rag handy to catch the runnoff.
« Reply #2 on: March 20, 2009, 08:47:33 PM »
Take the turn signal housing apart. Remove the VERY small phillips screw and remove the thumb knob. Spray some contact cleaner or (I use) brake cleaner till all the old grease is gone. I take Q tips to dig out the switch and be sure to move the switch back and forth as you rub the contacts. Finally, relube with SuperLube from Ace Hardware and reassemble everything. That should take care of it for 3-5 years.
Big IV
Iron Station, NC 28080
« Reply #3 on: March 21, 2009, 09:35:20 AM »
Have you added any other electro-suckers to your bike? Some of the other accessories can cause blinkers to slow down as they try to share. If you've added anything recently, unplug it and see if that helps any. If so, you need to re-wire how you have your accessories hooked together.
Or it could be dirty.
"Ride Free Citizen!"
VRCCDS0176
« Reply #4 on: March 21, 2009, 07:33:58 PM »
Mine does that to, esp when its below 40 deg. The 4ways come on right away but blinker is slow. Its fine in warm weather.  Evil
RP#62
Gilbert, AZ
« Reply #5 on: March 22, 2009, 05:46:30 AM »
That means that the grease in the switch has hardened and is keeping the points in the switch from making.  I don't know if you can fix this by spraying.  On mine, I had to take the switch apart and clean all the old grease out, (it had the consistency of wax). Once cleaned and regreased, it worked like new.
-RP
F6Cruzer
Robbinsville, NC
« Reply #6 on: March 29, 2009, 08:00:05 AM »
I live near the Tail of the Dragon!
