November 21, 2025, 10:10:20 AM *
Author Topic: question on voltmeter hook up  (Read 1617 times)
CB1
DFW, TX
« on: June 28, 2010, 07:03:50 PM »
I have the Kuryakyn LED Voltmeter installed and hooked up to the lights in the speedo housing.
I only get one green light lit up while cruising down the road. most of the pictures I have seen show two green lights lit; Where would be a better place to wire it in? the headlight?
Thanks!
Chris
Warlock
Magnolia, Ms
« Reply #1 on: June 28, 2010, 07:17:26 PM »
Mine did the same thing. Ran me a hot wire from the battery to the headlight and all is fine.
David
CB1
DFW, TX
« Reply #2 on: June 28, 2010, 07:33:01 PM »
wouldn't that mean it is on all the time? or is it switched off when I turn the key to the off position?
I'm staring at the wiring diagram in the shop manual and I'm all cross eyed now... LOL
Thanks!
Chris
Warlock
Magnolia, Ms
« Reply #3 on: June 28, 2010, 08:20:37 PM »
Forgot to mention I have a fuse panel that only works when key is on. I ran the wire from there. The fuse panel has a relay to trigger it.
David
redflash
Southern New Hampshire
« Reply #4 on: June 29, 2010, 02:56:48 AM »
I only get one green as well, as long as that's normal for my hookup, I don't worry about it. At idle it's green unless I have the brakes on or it idles for a while. It also drops to yellow when the fan is on below 2000RPM. I suppose you could characterize it if you had an accurate DC power supply to record what voltage trips each successive LED. I doubt any two are exactly the same within 100 millivolts. (.1 volt)
« Reply #5 on: June 29, 2010, 05:15:52 AM »
I tried a few hot leads and foound that I didnt get a true reading like I did hooking directly to the battery.  Yes it would be onn all the time, but I put a switch in the ground wire (so my power wire from the battery stayed pure) so I can turn it on with the bike being off to check the battery charge
CB1
DFW, TX
« Reply #6 on: June 29, 2010, 07:22:58 AM »
great stuff!
thanks for the thoughts!
Thanks!
Chris
