May 03, 2026, 02:05:31 AM *
Author Topic: Pingel  (Read 1925 times)
Six Guns
Fort Worth, Texas
« on: July 05, 2010, 05:25:58 PM »
The Interstate that I am buying had a hydrolock condition about 30K miles ago. The current owner had it repaired at D&S Honda, Kawasaki in Arlington. For those of you that have gone to a pingel, did you go with the 1311CH model or the 1311CHV model? Was there another Pingel model that you went with? Is it easy to install? Any information you can provide will be greatly appreciated.     Smiley
Rocketman
Seabrook, Texas
« Reply #1 on: July 07, 2010, 02:42:45 PM »
I went with the CH model.  I don't know that there is any good reason to stay away from the CHV, other than personal preference.
I don't know of any other model that would work.  They all seem to point in different directions, and that one matches stock the best.  As for ease of installation, it was a piece of cake.  Empty the tank as much as possible (insert ride here), then pull it off.  Tip it forward to slosh remaining fuel to the front.  Unscrew the old one.  Screw in the new one.  Reinstall tank.  Place vacuum cap over intake runner that used to feed vacuum to your old petcock.  Install hoseclamp over fuel line, and reattach (hose clamp is usually necessary since the Pingel's nipple is slightly smaller than stock).  Install tank.  Install fuel.  Ride.
paul
« Reply #2 on: July 10, 2010, 05:30:14 AM »
I put one my bike also..the ch1311 from eastern performance...like around 97.00 shipped to your door..If you want help putting it on let me know..paul. early weekend morns. good...i like the pingle..i have always turned the fuel off since i've been riding so thats a non issue for myself... cooldude
paul
« Reply #3 on: July 10, 2010, 05:35:52 AM »
P.S...if you order it from eastern performance (cheapest i found) Just tell them / CH1311...If you mention Valkyrie it just seemed to to confuse the heck out of them../// Shocked
Six Guns
Fort Worth, Texas
« Reply #4 on: July 10, 2010, 05:50:37 AM »
O.K. Paul, thanks......     Smiley
paul
« Reply #5 on: July 11, 2010, 07:31:59 AM »
If you want to have a set of engine hangers chromed let me know..they look good after the big plastic knob gets removed..
Six Guns
Fort Worth, Texas
« Reply #6 on: July 11, 2010, 10:01:49 AM »
Paul, I'll let you know. Thanks....
Six Guns
Fort Worth, Texas
« Reply #7 on: July 31, 2010, 08:28:41 AM »
Paul,
 E-mail sent......
paul
« Reply #8 on: July 31, 2010, 04:53:01 PM »
Hey Six gun..My email is screwed up somewhere between the national board and the texas chapter board..can you try to send me a message on the national board and see if I get it..Thanks..I think your pingel was posted there wasnt it?? if not give me a shout at.// ate won sev ate knine won tree phive ate sicks... cooldude
Six Guns
Fort Worth, Texas
« Reply #9 on: July 31, 2010, 07:06:11 PM »
Paul,
 Instead of an e-mail, I just sent you a personal message on the TX Board.      cooldude
