January 31, 2026, 11:58:11 AM *
Author Topic: Oil Problem Oil Question  (Read 1857 times)
1272
« on: July 06, 2010, 09:44:05 AM »
 I used  Mobil  1 Synthetic.  since the 600 mile break in.
Time   for  This oil change-30000 miles .
 Local parts store no mobil Synthetic.
I was taking a 1000 mile trip so i put in Mobil clean 5000= 5/30 + my mobil M1-110 Filter. for short ride, wrong decision
Took 1000 miles and checked the oil ,"Foaming" on the stick so i drained it and found babbit in my foamy oil,
  Changed oil put in  mobil synthetic,New filter, rode home, no problem no foam.
 But the top end is  a little more noisy
 Any suguestions out there
thanks
Jack
#1272
Pete
« Reply #1 on: July 06, 2010, 10:38:41 AM »
Suggestion: Take the oil, the babbit, the filter and discuss it with you local Mobil rep.
That should not happen.
I have used the same oil in a lawn mower  with no problems, but have not used it in a Valkyrie.
It should have handled a 1000 miles with no problem.
Mildew
Live, Not Just Exist
Auburn, Ga
« Reply #2 on: July 06, 2010, 11:08:14 AM »
When I bought my big rig the oil changing folks asked if regular oil was in it or synthic was used. They said it's ok to switch to synthetic from regular oil but you can't switch to regular from synthetic. They said it causes big problems.
valkmc
Idaho??
Ocala/Daytona Fl
« Reply #3 on: July 06, 2010, 01:31:15 PM »
Never heard that I have switched from synthetic to regular in both my Jeep and Valk and have had no problems.
2013 Black and Red F6B (Gone)
2016 1800 Gold Wing (Gone)
1997 Valkyrie Tourer
2018 Gold Wing Non Tour
« Reply #4 on: July 06, 2010, 03:45:41 PM »
5w-30 is too light for a Valk.  70K trouble free with 15w-50 mobil 1. I don't even use 5w-30 in my wife's Lincoln.  Hoser
« Reply #5 on: July 06, 2010, 03:50:07 PM »
thanks
Jack
#1272
that oil has very low anti-foaming additives which are needed for trans gears.  u didn't memtioned which m1 syn u are using
« Last Edit: July 06, 2010, 06:06:23 PM by CA ExhaustCoatings » Logged
« Reply #6 on: July 06, 2010, 05:27:56 PM »
I dont think it was babbit and you heard no bearing noise. If you had enough to drain out that you could actually see then its not the bearings and you have more of a problem. But I really dont think it was and I really dont think you have a problem or one at least that wont show up now. You know the more I think about this question I think your talking about a Volkswagan, Harley or a lawnmower with splash lubrication. Roll Eyes
« Last Edit: July 07, 2010, 05:44:44 AM by Robert » Logged
