January 31, 2026, 01:40:23 PM *
Author Topic: VSS Signal on a 98 Tour Help  (Read 1630 times)
big papa bear
« on: July 15, 2010, 07:19:22 PM »
I have a bought a 250 audio box cruise control that requires a vehicale speed sensor, VSS, signal to operate.  With the cable driven speedometer I can't locate a VSS signal.  Audio box's directions say do not hook to the coil or tack.  I have seen some information about doing this with an electric speedometer.  Could there be a signal from the electronic control unit (aka ECU or brain)?  If anyone has any instructions or points of reference or general ideas, please let me know.
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: July 15, 2010, 08:28:19 PM »
To have a vss you would need an i/s.  The standard/tourers don't have one.
Marty
« Reply #2 on: July 15, 2010, 08:51:44 PM »
I hooked mine to the coil on the left side of the frame.
big papa bear
« Reply #3 on: July 16, 2010, 02:12:18 PM »
  Fudgie
thanks for the info .this was with the audiovox 250
