January 31, 2026, 01:39:50 PM
Parts fallin off
Topic: Parts fallin off (Read 2054 times)
groundpounder01
Parts fallin off
July 15, 2010, 07:27:59 PM »
I put a new rear tire on so I changed the copper exhaust gaskets as well. When i was laying on my back under the bike on the left side, a lock washer hit me on the cheek. Looked around while i hand the carbs off and i havent found where it went yet. It is black and the inside diameter is about 1/8". Any ideas?????
Re: Parts fallin off
July 15, 2010, 07:29:34 PM »
ok so to put on a new tire you had to get new exhaust gaskets and that made you remove the carbs........sounds like athe tech session from he!!
groundpounder01
July 15, 2010, 07:45:33 PM »
No, removed the exhaust for easyer access to the rear wheel and a good clean and polish. Had an exhaust leak so i put on new gaskets.
Found the washer. Over the winter cleaned out the carbs due to clogged jets. That may sound better now.
July 16, 2010, 06:27:53 AM »
I think I recognize that part.
Look here:
http://www.hdlparts.com/fiche_section_detail.asp?section=148592&category=MOTORCYCLES&make=HONDA&year=2000&fveh=3474
Part # 23 I believe.
groundpounder01
July 16, 2010, 01:41:24 PM »
Maybe I will check it out.
