January 28, 2026, 08:15:47 AM
resetting the clock
Topic: resetting the clock (Read 3881 times)
stormrider
Kinsey, AL
resetting the clock
March 22, 2009, 05:16:56 PM »
I've done it several times before but this time it refuses to cooperate. I push the proper button, it flashes on the display but nothing happens when I try to reset with other controls. BTW 01 interstate.
stormrider
Kinsey, AL
Re: resetting the clock
March 22, 2009, 05:34:43 PM »
okay, somebody come up with the easy fix, "Complete Guide to Resetting Your Clock on an Ineterstate for Idiots" please?????
PatrickDoss
Alabama
March 22, 2009, 06:17:20 PM »
Your switch might be dirty. Does it operate the other functions (volume up and down)?
stormrider
Kinsey, AL
March 23, 2009, 05:40:26 AM »
raido works fine. I've had this problem before and it magically started working after about the fourth try at resetting it. But not so this time. I'm chicken at taking something like this apart from past experience. It seems little microsopic springs are hinding inside things I take apart and jump put all over the place.
March 23, 2009, 07:29:50 AM »
P.D. is asking specifically if the volume control switch is working. You did not directly answer that question. So I'll ask you again.
Does the volume control switch raise and lower the volume?
You must understand that if the volume control switch still raises and lowers the volume, your problem then is
not
with the switch.
sugerbear
wentzville mo
March 23, 2009, 11:32:34 AM »
using electrical spay cleaner(contact cleaner), you need not take the switch apart.
just leave the bike turned off, spray into each switch, vigorously work the switches up and down a few times.
let it set for a while (to let everything evaporate) start and try all the controls. depending on how dirty they are
repeat.
worked for me and friends bike.
Novavalker
99 Interstate/2017 Goldwing
Reply #6 on:
March 23, 2009, 11:43:26 AM »
Try resetting the clock while the radio is on.
