February 01, 2026, 02:23:46 AM
Clutch replacement
Topic: Clutch replacement (Read 1715 times)
Sonny
Holt, Mo.
Clutch replacement
July 29, 2010, 02:58:42 PM »
My 99 Standard has 44,000 miles on it. I have no slipage in the clutch but have noticed on the sight glass the fluid is about half way down the window. I know the clutch has never been replaced. Also know I have run her pretty hard. What kind of milage is everyone getting before a clutch is replaced?
Is it something that can be done a lift in the garage or does everyone recomend the dealer do it?
Any input ????
What a great day, lets ride!
1999 Valkyrie Standard
2003 VTX, 1800C
Re: Clutch replacement
July 29, 2010, 03:03:36 PM »
Change the fluid and fill it up to the line........if if goes back down you have a problem, if it doesnt just ride it..........you dont have enough miles to worry unless you have really been abusing the old gal
Mr.BubblesVRCCDS0008
July 30, 2010, 07:39:39 AM »
I have 120K on mine, some of that pulling a trailer and I'm still running orginal clutch.
Sonny
Holt, Mo.
July 30, 2010, 11:00:30 AM »
Thanks that great, now that kind of input is what I like to hear. I will change the fluid and ride her for a while. I have not been that hard in it, more hiway twistin than anything.
2003 VTX, 1800C
upjeeper
July 30, 2010, 01:18:47 PM »
losing fluid could be slave cylinder
i'm doing mine tonight. it came to about $21 for the spring and 2 seals.
valkmc
Idaho??
Ocala/Daytona Fl
July 30, 2010, 04:15:44 PM »
I replaced mine or should say some parts of it at 64,000, the rivets popped out of the spacer disk, nothing else was wrong or damaged. You can do it yourself with a lift. The only trouble will be the spring on the clutch basket, I took mine to a local shop and they removed it for me. After I made the repairs and replaced the parts I took the basket back to the shop and they put the spring back on it for me.
2013 Black and Red F6B (Gone)
2016 1800 Gold Wing (Gone)
1997 Valkyrie Tourer
2018 Gold Wing Non Tour
