November 21, 2025, 02:39:06 PM
J B Weld
Topic: J B Weld (Read 1707 times)
Kilroy
Clearwater, Florida / Overland Park, KS
J B Weld
August 03, 2010, 05:25:03 PM »
I did the desmog a couple of years ago and used JB Weld to seal the holes left in the block. I added a buffalo nickle on the rear ones for a little bling. The nickles do not hold very well. It says on the lable of the JB Weld that it is good to 800 degrees. Any ideas on how or what I can use to hold the nickles in place.
Kilroy
"I was here, but now I'm gone"
Re: J B Weld
August 03, 2010, 05:31:11 PM »
Marine tex
tank_post142
south florida
Re: J B Weld
August 04, 2010, 06:46:19 PM »
run the nickles down to the jeweler and have them silver solder a short threaded stud on the back. tap the jb weld and screw them in. or if you re jb weld the holes the treads will provide a good grip for the nickels.
I got a rock
VRCCDS0246
Re: J B Weld
August 05, 2010, 06:22:59 AM »
A little dab of silicone will keep it there forever.
Kilroy
Re: J B Weld
August 05, 2010, 02:16:38 PM »
Thanks for the ideas. I thought of the pins on the nickles, my main concern is the heat of the engine.
Will the solder or silicon withstand the heat?
art
Grants Pass,Or
Grants Pass,Or
Re: J B Weld
August 05, 2010, 04:21:28 PM »
high temp silicone
bentwrench
Philadelphia,Pa.
Re: J B Weld
Reply #6 on:
August 05, 2010, 06:22:47 PM »
Scuff the backs of the nickels with some 50 or 80 grit and put them back with some more JB,they should stay put
bw
=> InZane XXV
