November 21, 2025, 04:13:56 PM
Timing belt change, when?
Topic: Timing belt change, when? (Read 1811 times)
garyr
August 05, 2010, 01:59:46 PM »
I can't remember if you change the belt at 60k or 100k...Thanks
I have an 02 with 62k and my alternator has a slight whine it never had before. I guess I might try and clean it over the winter or just put in a larger aftermarket one.
Currently Own
78 Street Tracker
79 XS 650 Standard
72 Yamaha DT2 250
74 Kaw 2 stroke S3 400 triple
74 Suzuki GT 750
06 Triumph Speed Triple
02 Honda Valkyrie-6cyl
09 KLR 650
Warlock
Magnolia, Ms
Re: Timing belt change, when?
August 05, 2010, 02:11:50 PM »
The book call for them to be inspected at 100,000 miles. I changed mine at 75,000 for piece of mind. Mine is a 99 so I changed them because of the age.
David
X Ring
VRCC #27389, VRCCDS #204
August 05, 2010, 02:24:07 PM »
Since Sandman was made in 10/96. When I do my 50K service in the next couple of months I'll be replacing them for the same reason Warlock did. Peace of mind due to the age.
Marty
August 05, 2010, 02:48:07 PM »
follow the manual. remember honda would allow a 7 warranty on these bikes, same as the GL1500s.
subura's have similar setup, belt is enclosed from elements but is subjected to higher underhood temps. Their belts are now rated at 105k. It was either '96 or '97 when EPA regs started the requirement of anything to due with emissions has to be warrantee for 100k miles. '95 suburas have belts rated at 60k. So what belt did I just put on my nephews subaru, the 100k kevlar belt which is actually cheaper than the 60k belt. As far as a I know all 100k belts are of a kevlar construction.
IMHO.
August 05, 2010, 02:48:55 PM »
Timing belts on anything today usually look good right up til the time they break.. Most folks do replace them on our monsters more on a time basis than mileage, just for peace of mind..
John J
England
August 06, 2010, 12:14:08 AM »
I changed mine at 20k (7 years old) on the basis that if you are thinking about it you may as well get it done just for peace of mind. After all, it's an easy job and not expensive.
Reply #6 on:
August 06, 2010, 04:56:50 AM »
I changed mine at 152,000 miles and nine years. It looked perfectly good when I took it out.
=> InZane XXV
