November 21, 2025, 04:13:45 PM *
Author Topic: Bad final drive  (Read 2458 times)
Warlock
Magnolia, Ms
« on: August 05, 2010, 04:21:22 PM »
Friend of mine just picked up a 99 I/S with 64000 miles. Was doing a service on it when I found splines worn about 50%. Unless I can find a rear end guess I'll be rebuilding this one. Even if I can find one I'll still rebuild this one for a spare in case other trouble down the road.
David
Red Diamond
Beaumont, Texas
« Reply #1 on: August 05, 2010, 05:03:35 PM »
David
Which splines were worn, the drive flange splines or the driven splines. If its the drive flange splines, no need to rebuild the whole final drive unit. If you need a final drive unit check Pinwall.
Warlock
Magnolia, Ms
« Reply #2 on: August 05, 2010, 05:23:15 PM »
Both are worn. I just spotted one on evil bay I might bid on. The female side is worn a little worst than the male. Looks like they have changed the male already at one point. The female are around 60% and the male around 50%.
David
SCain
Rio Rancho, NM
« Reply #3 on: August 06, 2010, 11:33:41 AM »
If you can find a GL1500 Goldwing rear from a trike builder, the male and female splines interchange with the valk. You will have to get a bearing pressed on and off, but this is an option.
Steve
Warlock
Magnolia, Ms
« Reply #4 on: August 06, 2010, 06:34:37 PM »
Have thought about that also.
David
NITRO
Eau Claire, WI
« Reply #5 on: August 06, 2010, 07:10:19 PM »
I saw earlier today that there are two for sale on Ebay for $200 buy it now from someone in Canada.
When in doubt, ride.
