November 21, 2025, 05:13:45 PM
Front fork question
Topic: Front fork question (Read 1670 times)
Front fork question
August 09, 2010, 08:15:44 PM »
My 99 IS i bought in may has some play in the front end, I thought it was the neck bearings but jacked it up and could feel no play at all in the neck bearings, but when I yank on the front fender rail, I feel play in the lower sliders. My question is, when rebuilding should both bushing in each leg be replaced, I have the split bushings already, should the solid ones also be replaced?
Thanks in advance
Anthony
Belgium
Re: Front fork question
August 15, 2010, 12:54:39 PM »
while you are in there, have them on hand an ready to replace.
the ease of mind it brings comes cheap for the price of a set of bushings.
Anthony
August 15, 2010, 05:31:57 PM »
Yup, change out all the wear parts!
Steve K (IA)
Cedar Rapids, Iowa
August 23, 2010, 07:34:53 PM »
Yea, what they said.
States I Have Ridden In
August 23, 2010, 07:54:50 PM »
I collected up all the parts that the manual said were wear-parts before I took my forks apart.
Some of the bushings (it's been two or three years now) showed obvious wear - I replaced them.
Some showed no wear at all - I left them...
-Mike "forks still work good"
=> InZane XXV
