January 31, 2026, 11:28:55 PM
starter button
Topic: starter button (Read 1884 times)
santa
Santa Tom
Ardmore, Alabama
starter button
August 10, 2010, 03:52:28 PM »
When I push the starter button all the way in it won't start. If I push it half way in it starts normal. New starter button assembly cost $98. Looking for a less expensive solution?
Santa
Re: starter button
August 10, 2010, 04:03:33 PM »
Take it apart clean/lube it and make sure the plastic isn't melted assemble and your good to go.
santa
Santa Tom
Ardmore, Alabama
Re: starter button
August 10, 2010, 04:07:06 PM »
Thank you!!
santa
Re: starter button
August 10, 2010, 04:07:40 PM »
There should a section in shop talk or the archives on how to perform starter switch maintenance..
Daniel Meyer
The State of confusion.
Re: starter button
August 10, 2010, 04:52:32 PM »
Here's the shoptalk link:
http://www.valkyrieriders.com/shoptalk/VSGPages/starterbutton.htm
CUAgain,
Daniel Meyer
Re: starter button
August 10, 2010, 06:59:21 PM »
While you're at it, do the mod that adds a relay in the headlight circuit. Takes a high amp load off that start switch, you won't have the same problem crop up again.
Another thought....have you installed higher wattage headlight bulbs? That increases the amp load even more, which in turn increases the possibility of burning the internal contacts in the switch.
Re: starter button
Reply #6 on:
August 11, 2010, 05:12:48 AM »
A friend of mine had that same problem would start, then not start. When we took his apart the little brass foot thing was stuck down into the plastic and it was so tight the spring under it was not strong enough to push it up to where it makes the conection with the four contacts.
If that brass thing doesnt spring up and down you are going to have to carefully free up its movement and get the spring back to life. I fussed with his for awhile and I think I could have got it working, but he was late for work, so I put my spare in there. just be careful you dont loose the tiny parts
