January 31, 2026, 11:29:47 PM *
Author Topic: Radio volume fluctuates  (Read 2431 times)
Hoghead
Kilgore, TX
« on: August 11, 2010, 09:07:21 PM »
On my 00 IS at 40mph or slower the volume of the radio goes down. 40 or above it plays very loud. It varies a little on the speeds. Is this normal?
2000 I/S. Coronado Blue & Silver
1984 V65 Magna. Really Fast Black
E. Texas Patriot Guard Rider
Valkahuna
DeLand, Florida
« Reply #1 on: August 11, 2010, 09:11:12 PM »
Sounds like it is part of the Automatic Volume Gain. You can control how loud it gets. I'm not sure about the 40 MPH though, on my 2001 I/S there are several levels. I thought one was around 50 MPH, and the other around 70, but could be 40 as well.
2014 Indian Chieftain
2001 Valkyrie I/S
PhredValk
Edmonton, Alberta, Canada
« Reply #2 on: August 11, 2010, 09:56:49 PM »
Push the V Mode button, maybe a couple times, untill it says AVC. Within 4 seconds, push the Vol switch up or down to select Hi, Low or Off. The volume increases with speed depending on what this is set at. Other controls change things like bass, treble, and Ambience. E-mail me if you would like a PDF of the I/S radio controls, kindly supplied to me by one of the members on this board.
Fred.
VRCCDS0237
Baloo
Rimouski, Canada
« Reply #3 on: August 12, 2010, 06:42:22 AM »
Yep... As Fred said...
Same here. Nice feature on the IS radio that can be adjusted to suit your taste.
Never ride any faster than your guardian angel can fly...
SCain
Rio Rancho, NM
« Reply #4 on: August 12, 2010, 07:52:06 AM »
The AVC only works using the Fairing Speakers, if you plug in a helmet headset it stays on but doesn't adjust as your speed increases.
Steve
Hoghead
Kilgore, TX
« Reply #5 on: August 12, 2010, 07:55:06 AM »
Thanks everyone, big help. Those controls are quite complicated to figure out. Maybe its because I haven't read instructions. haha. Ride safe everyone.
NITRO
Eau Claire, WI
« Reply #6 on: August 12, 2010, 09:44:17 AM »
The radio/CB  control instructions are worth a quick read. Go through it while you're sitting with your bike so you can try everything out.
When in doubt, ride.
« Reply #7 on: August 12, 2010, 10:33:34 AM »
Yep, there's a lot of good information in the owners handbook.
Would do you good to get a manual also!
MP
North Dakota
« Reply #8 on: August 13, 2010, 05:41:24 AM »
+1 on getting an operators manual.  Some come up on ebay.  There is a place that also sells them, besides Honda.
You need one to figure out how to run the radio controls!  LOL
MP
"Ridin' with Cycho"
cef2lion
Central PA
« Reply #9 on: August 13, 2010, 06:16:05 AM »
Does the IS owners manual contain information on using the radio or is the radio instructions a separate manual. I have a PDF on the CB operation.
MP
North Dakota
« Reply #10 on: August 13, 2010, 06:19:25 AM »
IS owners manual has the info on using the radio and controls.  The CB one has more info on using the CB.  Should have both if have a CB.
MP
"Ridin' with Cycho"
Big Rig
Woolwich NJ
« Reply #11 on: August 13, 2010, 09:41:52 AM »
Based on RPM not MPH...
Kaiser
Gainesville, FL
« Reply #12 on: August 13, 2010, 12:18:42 PM »
I'm pretty sure it is based on speed and not RPM.  If I wind it out in 1st and/or 2nd, the radio is not as loud as just cruising at higher speeds with a lower RPM.
YMMV
Baloo
Rimouski, Canada
« Reply #13 on: August 13, 2010, 12:52:03 PM »
Same here... definitely based on speed...
Michvalk
Remus, Mi
« Reply #14 on: August 13, 2010, 02:40:12 PM »
When the pickup for my spedo on my interstate quit working, so did my AVS
YMMV
