February 01, 2026, 12:56:21 AM *
Author Topic: Bike seems to run "Rich" when at idle  (Read 3260 times)
Bonzo
« on: August 13, 2010, 12:46:55 PM »
just going by smell. Is there a speck available, or any ideas to check and adjust?
Woops, I'm sorry.
« Reply #1 on: August 13, 2010, 01:57:16 PM »
That may or may not be actually happening.
What is your actual gas mileage for the bike.
That would be a place to start.
Have you an aftermarket exhaust?  Maybe modified stock exhaust?
What has been done if anything to the carburetors?
You get the idea.
A bit more information would help a lot.
Finally, in an enclosed area, the exhaust fumes can seem to be very potent and may influence you to think the bike is running rich because it's making your eyes water.
Are you using the choke to excess? That may do what you are experiencing!
« Reply #2 on: August 13, 2010, 02:00:56 PM »
Do you know what,if anything, has been done to the bike?? Like maybe a switch from 35 to 38 lows??  All that said,, if its burning your eyes after a few minutes but keeps on running,, its probably normal.. If it still idles smooth and runs well,, run it..
Valkpilot
What does the data say?
Corinth, Texas
« Reply #3 on: August 13, 2010, 06:19:04 PM »
When you think it is running rich, let it run for few minutes, then stop the bike an pull a plug or two.
Use this to determine if it's actually rich or not: http://www.ngksparkplugs.com/tech_support/spark_plugs/faqs/faqread.asp
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
FLAVALK
Winter Springs, Florida
« Reply #4 on: August 13, 2010, 06:36:40 PM »
I think most all Valks more or less have that smell, at least the ones I've been around.
« Reply #5 on: August 13, 2010, 07:46:39 PM »
Easy is having a friend who has a exhaust gas analyzer the type they use on DMV inspections to run your bike. Next is just lean the idle screws and see how it runs. But you haven't said how your idle is smooth,rough is the only complaint the smell? If it is rich and you lean the idle screws you may find the bike running better.
« Reply #6 on: August 14, 2010, 04:56:40 AM »
Leave the bike alone and just ride it.
Anytime you are in an enclosure, like a garage or lean to, you will smell exhaust fumes.
Ya don't have a catalytic convertor on it like ya do your car.
Bonzo
« Reply #7 on: August 14, 2010, 10:01:04 AM »
Bike idles smooth, stock exhaust and I have not touched the carbs. Gas mileage is around thirty, but I have a heavy right hand. This is not a new problem, but was mentioned to me while i pulled into a local tavern and a buddy of mine mentioned that the bike smelled rich. My answer was it does run rich at an idle.
By the way I never start the bike in my garage and  try to use the choke minimally.
I like the advice: Leave the bike alone and just ride it!
Woops, I'm sorry.
skromfols
You only go around once
Valley Springs, Calif
« Reply #8 on: August 14, 2010, 04:31:13 PM »
I agree with Valkpilot.  It would take very little effort to let the bike idle for a few minutes then pull a couple of plugs.  30 mpg sounds very low, since I usually get around 40 mpg and I don't ride slow.
Stan
KW
West Michigan
« Reply #9 on: August 14, 2010, 05:19:59 PM »
I'm NOT calling anyone a liar . . .  but how in the world do you get 40 mpg? Wow! Do you stay off the throttle? And, if yes, how do you do that on a VALKYRIE!?!? Now if you tell me you drag race crotch rockets street light to street light and get 40 mpg, then yes, I'm calling you a liar!
I got 38 mpg once. . . I think I was not feeling well or something. I average between 32 and 36, but closer to 32. . . .
« Reply #10 on: August 14, 2010, 06:09:48 PM »
With that report I would leave it alone too. It sounds like all is well and your mileage is good forget about it. cooldude
Red Diamond
Beaumont, Texas
« Reply #11 on: August 14, 2010, 08:10:55 PM »
I get 40MPG consistently, open hwy riding between 65-70 on my Interstate. The Tourer, about 38MPG. I/S is '99, Tourer is 2K. You will find that most get around these figures, unless they really push it above 70MPH.
Farther
Quimper Peninsula, WA
« Reply #12 on: August 14, 2010, 08:21:58 PM »
I only get 40 when I keep it under 40 and then not often.
~Farther
« Reply #13 on: August 15, 2010, 08:10:35 AM »
Yup!
40 mpg around town and interstate, all the time.
Get a little better on the highway, steady traveling (throttle) 41 mpg to 42 mpg.
Jack it up to above 3300 rpm's and the mileage suffers a loss of about 3 to 4 mpg.
KW
West Michigan
« Reply #14 on: August 15, 2010, 10:50:47 AM »
Did I mention . .  that I'm  . . . a 'tad' heavy? Still, I thought mid-30's was the normal for a Valk? Cheesy
John U.
Southern Delaware
« Reply #15 on: August 15, 2010, 03:47:23 PM »
A 6 degree trigger wheel or a 4 on an I/S will improve your mileage, so will the ECT mod.
Of course the right wrist will be the determining factor.
Bonzo
« Reply #16 on: August 16, 2010, 07:21:13 AM »
OK I will not play with the carbs, but I will change the airfilter.
MPG? Oh I guess 30-31 aint bad I am 330 and can't go under 70!!
Woops, I'm sorry.
Spirited-6
Nicholasville, Ky.
« Reply #17 on: August 16, 2010, 10:03:41 AM »
Yup!
Boy, I`m running way "RICH" or I don`t know how to fig. MPG.  Every once in a while I will get a 40 MPG and wonder what the hell I did. I ran above 3,000 rpm`s for the trip home from the Whisky Run and got about 33 MPG.  Normanly I will get about 34-38 MPG the way I ride, and that is not flogging this sh## out of the Jade Lady. Which I would never do, cause she is my "HOME" away from home. Damn, I need "help"  Embarrassed
Spirited-6
Bonzo
« Reply #18 on: August 20, 2010, 04:01:48 AM »
So I did an experiment yesterday, On my round trip to work, I drove very mellow, never exceeded 3200 RPMs. No quick starts and got 34.83 mph. Fueled up to the same spot in the tank and used Sonoco regular. 1997 standard, windshield, Baker Air Wings, Dark Side Cooper Zeon Sort A/S 105 55 16
Woops, I'm sorry.
Farther
« Reply #19 on: August 20, 2010, 09:18:34 AM »
I don't think you can compare tank to tank and get an accurate reading of fuel mileage.  There are too many variables when doing that.
~Farther
« Reply #20 on: August 20, 2010, 09:59:47 AM »
That is very true!
You have got to run through three or four tanks of gasoline to get an accurate figure.
That way if you miss by a cup or so of gasoline it will not skew the final figure by much at all.
My last was figured on 2,500 miles.
Bonzo
« Reply #21 on: August 20, 2010, 10:37:38 AM »
Well thats my report, take it or leave it. I need to ride the way I like to ride and go back to my 30 mpg.
Woops, I'm sorry.
Valkpilot
Corinth, Texas
« Reply #22 on: August 20, 2010, 03:02:08 PM »
I think you're in the same ball park as most Valk riders' mileage.  Low to mid-thirties is pretty typical, falling below 30 when pushing it hard, especially in the wind.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #23 on: August 20, 2010, 03:44:24 PM »
Hardley ever below 30, occasionally  get 40.  I dunno!   ??? hoser
Bonzo
« Reply #24 on: August 21, 2010, 04:09:05 AM »
Rode it like I stole it yesterday, same trip as before but with Friday going to the country traffic. Ran it like a raped ape when the road opened up (How many more metaphores can I use?). Paced  (not raced) some little sports cars for about 11 miles, very fast!  30.45 MPG. End of science project!
Woops, I'm sorry.
« Reply #25 on: August 21, 2010, 12:41:57 PM »
Yup, I know what you mean.
Love them fast cars!
In my early days they were called "bear bait"
They are the ones who get the speeding tickets!
