February 01, 2026, 12:55:36 AM *
Author Topic: Valk chokes at steep acceleration  (Read 1989 times)
Oldswimr
NE North Carolina
« on: August 16, 2010, 09:33:57 AM »
I was getting away froma tailgater last week, and as I turned and rapidly accelerated, I stretched the RPM's into the upper 4's low 5's maybe, (possibly a little higher..) and just before I shifted from 2nd to 3rd, the engine choked or faltered, however you might describe it. I eased back on the throttle and it recovered, but it was a little unsettling at best.
Any ideas..?
"Yes, it's fast, no you can't ride it.."
Spirited-6
Nicholasville, Ky.
« Reply #1 on: August 16, 2010, 09:40:06 AM »
Hey Hot Rod. I think you hit the "rev limter"  Wink
Watch your TACH.  Embarrassed
Spirited-6
« Reply #2 on: August 16, 2010, 09:42:51 AM »
Things happen fast when you're in first or second gear.
« Reply #3 on: August 16, 2010, 10:06:16 AM »
Yep, you could have very well hit the rev limiter [appr 7200rpm] since you were still in 2nd.. Try and see if it happens again while in 3rd or 4th.. If it happens in the higher gears then you could have a fuel delivery issue,, if it runs good,, then run it and don't worry about it..
Daniel Meyer
The State of confusion.
« Reply #4 on: August 16, 2010, 10:29:32 AM »
If you didn't hit the rev limiter it is the petcock. Do a leak down test on it just to be sure. (pull vacuum on the vacuum port...it should hold).
CUAgain,
Daniel Meyer
