February 01, 2026, 12:55:16 AM
adjusting valves
Topic: adjusting valves (Read 1993 times)
chuckie
adjusting valves
August 18, 2010, 02:10:15 PM »
how do you fellas torque the lock nuts on the valve adjusters. I remember my dad's old chevy had to be a tad tight as the gap would change after tightening the lock nut. Same thing here?
thanks Chuckie
Thunderbolt
Worthington Springs FL.
I just do it by "feel"
August 18, 2010, 04:03:27 PM »
So far I have had good luck.
ricoman
Sarasota, FL
Re: adjusting valves
August 18, 2010, 05:01:49 PM »
I'm sure there is a torque spec but never thought about it.
Hold the screwdriver and tighten the nut, hard. Then check clearance again. Do all twelve and button it up.
Madmike
Campbell River BC, Canada
August 18, 2010, 08:43:51 PM »
..just take the clearance out of the threads with the lock nut just past finger tight and check your lash and adjust from there then when you are happy tighten up the nut and verify the lash and move on............
August 19, 2010, 04:56:39 PM »
Just tighten down snug and keep the screw driver holding the adjuster so it wont turn. If it does tighten down to much loosen the adjuster nut and keep a screwdriver in the adjust put tension on the screw driver as to loosen it as you loosen the nut. Dont loosen either all the way just a little probably the amount it tightened and then retighten the nut with the tension on the screw driver loosening it so it doesn't tighten down any more. If you need to use a torque wrench to tighten the adjuster maybe you would be better seeking some help for this job.
chuckie
August 20, 2010, 07:36:51 AM »
A buddy who has worked on valkyries tells me that 17lb is the torque setting on the locknut.
Thanks all for replies
Chuckie
