November 21, 2025, 06:31:54 PM *
Author Topic: popping in driveline?  (Read 1709 times)
wildbill56
Strawn Tx
« on: August 19, 2010, 01:46:55 PM »
I've just got a popping in my driveline,under power or backing off too! Any ideas?
« Reply #1 on: August 19, 2010, 01:52:25 PM »
Sounds like splines or drive shaft/pinion cup about to go.
MP
North Dakota
« Reply #2 on: August 19, 2010, 03:16:47 PM »
u-joint or splines/pinion cup.
MP
"Ridin' with Cycho"
« Reply #3 on: August 19, 2010, 03:30:13 PM »
You can hear it and you think it's coming from the drive line:
But,
You can't feel anything?
I think you ought to feel it,,, like it's jumping a tooth on a chain sprocket, something like that!!!
Disco
Republic of Texas
« Reply #4 on: August 19, 2010, 03:37:19 PM »
If it turns out to be the u-joint, mine didn't make any noises until immediately before it came apart.  However, I felt it failing for some time - first as slop or lash as load was applied or relieved from the drive line that I incorrectly attributed to the dampers in the rear wheel.
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
wildbill56
Strawn Tx
« Reply #5 on: August 20, 2010, 02:34:54 PM »
thanks for the info.started tearing her down this evening.
« Reply #6 on: August 21, 2010, 01:18:34 PM »
Pretty easy to inspect the u-joint.
Remove the rear brake pedal assembly and pull back the rubber boot!
Mr.BubblesVRCCDS0008
« Reply #7 on: August 21, 2010, 02:35:35 PM »
I blew a pinion cup and driveshaft and it never made a noise until it let go. I replaced everything from output shaft of engine to final drive.
B
Capital Area - Michigan
« Reply #8 on: August 28, 2010, 06:22:32 PM »
Ditto. I was on a trip (a holiday wkend) ...noise one day and she came apart the next.
