February 01, 2026, 03:51:54 AM *
Author Topic: Trigger Wheel question  (Read 1887 times)
Blister
Washington
« on: August 29, 2010, 09:44:13 PM »
I was looking through some stuff that came with the Valkyrie when I got it and noticed a Trigger Wheel. I'm assuming mine has been changed. Can anyone tell me if you can by looking at them if they're stock or not ?. Didn't really want to tear into her because she's running good. Haven't done any searching yet as thought I'd take the easy way and ask here. Thanks in advance.
"Life is what happens when your busy making other plans"
GJS
Today is the tomorrow you worried about yesterday.
Vancouver Island, BC, Canada
« Reply #1 on: August 29, 2010, 09:53:26 PM »
No, they look the same.
Do you know if you have a 4 or 6 degree wheel?
I had a 6 on my Interstate and I have gone back to stock. I prefer the consistent response across RPM range with the stock wheel. WIth the 6, I got a snap at 3300-3500 rpm. I was a rush alright, but I never got used to the lag at the low end a. nor did I enjoy the snap.
Cheers,
Glenn
The tragedy of life is not that it ends so soon, but that we wait so long to begin it.
- W. M. Lewis
ricoman
Sarasota, FL
« Reply #2 on: August 30, 2010, 03:04:12 AM »
A non-stock trigger wheel will usually have a 4 or a 6 stamped on the front.
Unfortunately you can't see the trigger wheel unless you take off the crank pulley and plate covering it. A bit of work to get there.
« Reply #3 on: August 30, 2010, 03:09:31 AM »
Post a photo of it, if you can.
Blister
Washington
« Reply #4 on: August 30, 2010, 08:55:35 AM »
Well, there's nothing stamped on it other than a stamp that says "outside". I guess I'll find out if I ever have to get in there. For now I think I'll leave well enough alone. It just got me curious. Thanks for the replies.
« Reply #5 on: August 30, 2010, 12:23:34 PM »
Yes, that's the stock wheel!
Slammer
Lafayette,La.
« Reply #6 on: August 30, 2010, 12:28:00 PM »
are solid with only a center hole and stock wheels are stamped with oval holes all the way around.
« Reply #7 on: August 30, 2010, 12:42:43 PM »
You are correct Slammer!  I was mistaken. I had to go out and dig up my old wheel.
That means Blister has an aftermarket wheel.
If the wheel is washed good the number stamped on the wheel should become evident. 4 or 6
Slammer
Lafayette,La.
« Reply #8 on: August 30, 2010, 02:04:53 PM »
In her eyes I've never been right about anything, now I have proof!!!!!!!!
