February 01, 2026, 03:51:37 AM *
Author Topic: Cooking and Fartin'!  (Read 2044 times)
DarkMeister
« on: September 03, 2010, 01:59:26 PM »
Probably unrelated but...
Cooking on the right: I invariably get much more heat on my right foot / leg than I do on the left. The IS that I ride sat for a long time and was serviced for "set'n" before I got it. Carbs, ya think?
Flatulence on the left: had an a/m exhaust installed at a shop. Now, I get major popping and backfiring upon deceleration - but only on the "cool" side. Did a search and learned that glasspacks will pop and fart; but what intrigues me is that it only happens on the left side, ever.
Haven't got a clue about carb adjustments, but if that's what it needs, I'll take it in.
Any learned opinions appreciated...
Pete
« Reply #1 on: September 03, 2010, 02:47:27 PM »
Go to Harbor Freight and get( or borrow one from a friend) the 2x.xx heat gun and check you exhaust temps.
alph
Eau Claire, WI.
« Reply #2 on: September 03, 2010, 03:44:23 PM »
can't help ya, but you did get my attention with the "farting" thing!!   Cheesy
shortleg
maryland
« Reply #3 on: September 03, 2010, 06:05:40 PM »
  Poping on one side my be an exhaust leak
at headers.
  Good idea the heat gun.
       Shortleg[Dave]
Kymbo
South Australia
« Reply #4 on: September 04, 2010, 07:23:47 AM »
Sounded like a BBQ at my place
John U.
Southern Delaware
« Reply #5 on: September 04, 2010, 05:52:18 PM »
If you've had a new exhaust system installed it may be that the exhaust header nuts need tightening. Generally they need to be snugged up a couple of times. Just go easy those buggers will snap off.
The other problem may be clogged slow jets on the cool side. Does it idle smoothly? If not a strong dose of Techron might fix you up. It's cheap enough and doesn't require wrenches and laying on your back like tightening the exhaust header will.  Wink
