February 01, 2026, 05:37:38 AM *
Author Topic: Subtle and inexpensive changes for a real increase in POWER  (Read 2699 times)
Momz
ABATE, AMA, & MRF rep.
« on: September 17, 2010, 06:57:07 AM »
Back in 2003 at INZANE, I had the oppurtunity to talk to the boys (Andy & Justin) from Viking. I asked what is the most effective way to make my Valk faster. They assumed I had a standard or tourer, and was told "use an I/S ICM and I/S carb springs".
Lamont said "make it lighter and polish the intakes". I was able to remove more than 80 pounds by removing anything that really wasn't necessary.
Big BF suggested lifting the tank on a standard to increase the air the air filter intake.
Well I installed the I/S carb springs, desmog, raised the tank, polished the intakes, and did the simple ECT Mod. I thought it was fast until yesterday. I bought a I/S ICM and installed it, started the bike and it really sounded mean.
I will admit that the bike has Cobra 6x6 pipes that may not increase power.
I took it out on Hines Drive for a little tryout.  I will say this,.......that sucker is FAST. It lifts the front wheel when shifting into second without provcation.
This bike is gonna get me a few tickets without trying,.....$hit I never believed it could get better. I was wrong!
« Last Edit: September 19, 2010, 06:35:38 AM by Momz » Logged
ALWAYS QUESTION AUTHORITY!
« Reply #1 on: September 17, 2010, 07:41:02 AM »
I was able to remove close to 80 pounds by removing anything that really wasn't necessary.
could u list what u did?
thanks
Redline +
Northwest Washington
« Reply #2 on: September 17, 2010, 09:04:44 AM »
I removed 130+ pounds from my Valk. It's now faster, has increased lean angle and much quieter.
But it wasn't inexpensive.
Redline  Cool
« Last Edit: September 17, 2010, 09:36:57 AM by Redline :) » Logged
Momz
« Reply #3 on: September 17, 2010, 09:52:59 AM »
CA ExhaustCoatings, weight is easy to remove if you think about what you really don't need.
Removed front fender and replaced with VTX C fender, removed front turn signals and replaced with small cateye LED signals, removed windshied and saddlebags. I removed NC light bar, tank badges and rear fender reflectors, removed entire PAIR valve system, removed the original crash bars then added XF6 beast bar. I also changed all the oringinal foot pegs with lighter custom units, removed the rear turn signal/licence plate mount then added a custom curved plate bracket and added a LED tailight/turn signal array into the OEM tailight. Removed the entire passenger backrest/carrier and all brackets and fasteners. I replaced the OEM seats with a Saddlemen "profiler" seat that is far lighter than even the rider portion. The OEM shocks were replaced with 11.5" Progressive units that are quite a bit less heavy than the Honda shocks. I drilled lightning holes wearever it was safe to do so. Replaced the OEM shift lever with an aluminum CBR1100XX shift lever. I accidentlly broke the rear brake Master Cylinder cover so I removed it. Replaced the battery with a smaller "Gel Cell" unit.
I had Cobra pipes on the bike when purchased it, but I'm sure they are somewhat lighter than the OEM exhaust system.
I have even more ideas on where I could reduce weight, but that is going to be a winter project.
« Last Edit: September 19, 2010, 06:33:34 AM by Momz » Logged
Varmintmist
Western Pa
« Reply #4 on: September 17, 2010, 12:11:24 PM »
thanks
Carrots instead of cake.
 Grin
Churchill
tank_post142
south florida
« Reply #5 on: September 17, 2010, 01:09:55 PM »
[/quote]
Redline  Cool
[/quote]
Do you have to pay alimony?
I got a rock Sad
VRCCDS0246
Redline +
« Reply #6 on: September 17, 2010, 02:36:12 PM »
Redline  Cool
[/quote]
[/quote]
No...I bought her a bike.
Redline  Cool
PAVALKER
Pittsburgh, Pa
« Reply #7 on: September 17, 2010, 03:10:24 PM »
thanks
 Grin
 Grin Grin Grin   Not even Carrot Cake either......
Most of us are adding chrome here and there, GPS and audio stuff.  Hell.... I bet I could lose 80 lbs off the Valk by just emptying the trunk and saddlebags......   Wink
John
john
tyler texas
« Reply #8 on: September 17, 2010, 05:42:17 PM »
Carrots instead of cake  .....      2funny
vrcc # 19002
Darren
Lees Summit, Missouri
« Reply #9 on: September 19, 2010, 06:07:42 AM »
Where can I find an IS ICM? Looked on EBay but have had no luck.
Momz
« Reply #10 on: September 19, 2010, 06:25:27 AM »
I believe that I bought Pinwalls their last one during their 20% clearance sale.
However HDL has them and will ship for free.
You may also check with Big Mike at valkyrieblingandmore.com
