July 20, 2025, 10:15:28 PM
All I did was clean the K&N air filter....
Topic: All I did was clean the K&N air filter.... (Read 1407 times)
F6CTrider
Denver, Colorado
September 17, 2010, 10:40:02 PM »
All I did was clean the K&N air filter....Now It seems to be running too rich and misfiring at low throttle positions. Problem goes away when I open it up???????
Did I miss or god forbid, mess something up?
I am running sea foam through it now, and have just changed the plugs (trying to eliminate possibilities)
Any thoughts?
I am not overly gifted with a wrench, carb rebuild may be over my head.
shortleg
maryland
Re: All I did was clean the K&N air filter....
September 17, 2010, 11:10:51 PM »
More than likely too much oil in filter.
Shortleg[Dave]
9Ball
September 18, 2010, 05:39:11 AM »
+1, too much oil will block air flow causing the condition you describe....
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
September 18, 2010, 05:59:14 AM »
+2 on too much oil.
Mine I use the cleaning solution that K&N has, then when it is dry, we have an oil misting machine, at the shop, we do a light spray and ready to rumble.
Only other thing it could be is ya knocked a hose off in the take apart/re-install.\Personally, I'd start looking at hoses knocked off or cracks in them 1st.
F6CTrider
Denver, Colorado
September 18, 2010, 06:08:33 AM »
Put me down for a lesson learned...Go lightly with the red oil!!!
Thanks for the wake up call, it was too appropriate for me to see.
=> InZane XXV
