February 01, 2026, 05:38:55 AM
dragging front brakes
Topic: dragging front brakes (Read 1693 times)
Matsumike
September 20, 2010, 02:14:43 PM »
I did a search and found just a little discussion of the possibility of too much brake fluid in the resivoir, which is not my problem. I am rebuilding (mostly cosmetic) a tourer, and while up on the lift, I tried to spin the front wheel and find that the front brakes are rubbing very bad. I must mention that this gril has been out of commission for some time and sat for about 2 years, without being ridden (sad girl).
I have not touched the front brakes, nor replaced front tire as it is new. What suggestions would you have? It does not look like she needs new pads on front - only rear.
Is there are quick way of freeing up the front brakes?
Thanks. Mike.
Colin
My old job
Orba, Spain
Re: dragging front brakes
September 20, 2010, 02:19:02 PM »
Pull the front callipers, pop the pistons and clean them up. Clean all the pins and re-assemble with some anti-seize . I finished rebuilding my standard about 4 months ago and it was in a similar condition and that cured it.
Colin
VRCC Espana
My Bumble Bee re-build
sugerbear
wentzville mo
September 20, 2010, 02:26:35 PM »
and change all the fluids.
