February 01, 2026, 05:38:52 AM *
Author Topic: Top vent on pumkins  (Read 1922 times)
Warlock
Magnolia, Ms
« on: September 20, 2010, 03:09:16 PM »
There was a discussion about the top vent being a 1 way check. Not a one way. Will vent and also let the fluids out if turned upside down. Was re-doing a rear and removed it. Just a tube with a hole in it with a chrome cap on it to keep water out.
David
« Reply #1 on: September 20, 2010, 05:04:09 PM »
yep, just pulled one the other day, didn't get time to post, found the same thing.
no filtration and prevention of water intrusion is the reason honda recommends a change every 24k miles.
http://www.machinerylubrication.com/Read/273/gearbox-contamination
RUDE DOG - Steelers
New Jersey - VRCC # 3966
« Reply #2 on: September 20, 2010, 08:25:04 PM »
What do you do if yours broke off?
Warlock
Magnolia, Ms
« Reply #3 on: September 20, 2010, 08:57:39 PM »
Did the chrome cap break or part of the pumpkin itself? If just the top part I would try and take like a ice pick and drive beside the part that was left in there. Should be able to bend it and remove it. The tube has a ridge in it to make it seat into the pumpkin.
David
RUDE DOG - Steelers
« Reply #4 on: September 20, 2010, 09:30:40 PM »
The chrome cap broke off.  Ive left as is so far.
Daniel Meyer
The State of confusion.
« Reply #5 on: September 21, 2010, 10:01:38 AM »
It's just pressed in. Get a new one, see if you can get the stem of the old one out. lightly coat the edge with sealant of your choice, and stick in.
It's not a one-way...it's sort of a baffle/drainback, but reasonably free flowing. Yes, dust and water can intrude, but not all that easily.
CUAgain,
Daniel Meyer
JetDriver
Columbus, OH
« Reply #6 on: September 21, 2010, 11:02:12 PM »
My chrome cap "broke off."  (Don't ask)  I used Gorilla Glue.  Clean both the vent top and the inside of the cap as best you can.  Per the instructions, I moistened the top of the vent with water, put a dab of glue inside the cap, and rubber banded it on for my "clamping."  Figure out and practice with the rubber bands before you glue it, so that when you apply the glue, you are ready.  The trick, as I remember, was to get the rubber bands to hold it on flat.  They kept slipping, so that the cap would be canted w/o nearly as much surface area touching the vent top.  I used those heavy, fresh produce rubber bands.  (You DO eat vegetables, right?)  My cap has been on for 4 months and 6000 miles.  Will it last forever?  I don't know, but I'm pleased so far.
« Reply #7 on: September 22, 2010, 04:37:48 PM »
I would use permatex ultra grey or their ultra black. it will stick to metal and is not affected by oils.
http://www.permatex.com/products/automotive/automotive_gasketing/gasket_makers/auto_Permatex_Ultra_Grey_Rigid_High-Torque_RTV_Silicone_Gasket_Maker.htm
