November 21, 2025, 10:21:10 PM *
Author Topic: Noise from Alternator/Tranny Chrome Cover  (Read 1850 times)
Rio Wil
« on: September 22, 2010, 10:26:13 PM »
Over the last several thousand miles, there has been a considerable increase in the noise coming from the alt/tranny cover .  Removed both to inspect for cracks and poor fitment....etc, and really didn't see anything.  So I am thinking the noise is a symptom of something else and they simply serve as a echo chamber and  amplify the underlying cause.  So, has anyone found a solution aside from undercoating the covers which just addresses the echo chamber aspect and not the cause.  If I recall, there is a 'rubber'  damper on the end of the alternator, can that the actual cause.....any thoughts.  Removing the chrome is not a desirable solution....gotta have bling!!
Spirited-6
Nicholasville, Ky.
« Reply #1 on: September 23, 2010, 06:57:47 AM »
The bigger question would be " WHY THE INCREASE". That aside, I installed trany covers on my Tourer and the noise increase almost drove me to the point of removing said covers. I did undercoat, no help, then I put Dynamat over the coating. It helped to the point I can stand the gear noise at lower RPM`s. I don`t understand why you would have a "increase" in noise since you did not just install anything.  Undecided  I would look at Alt. for the noise. Good luck.
Don
Spirited-6
sugerbear
wentzville mo
« Reply #2 on: September 23, 2010, 08:02:56 AM »
did you change oil type or weight?
(treading lightly, don't want to start an oil war ???) 2funny
Joe Hummer
Arnold, MO
« Reply #3 on: September 23, 2010, 08:21:34 AM »
Or are you close to or past due on your next scheduled oil change?
Joe
1999 Valkyrie Interstate
Rio Wil
« Reply #4 on: September 23, 2010, 02:36:44 PM »
There have been dozens of folks complain about tranny noise over the past few years and for 100K miles I never had any.....and didn't understand what they were talking about.....I didn't have it.  Now in the last 12-15K miles (3 oil changes) the dam things are driving me batty.  They are not loose, I put sound deadening material on the back side, only the alternator side is noisy.  It does not sound like a noise that would be sympathetic to bad alternator bearings nor do I hear any roar/growl/squeal that would suggest bearings. If you put your hand on the trans and alt cover and apply significant pressure, it quietens the sound down..all this does is simply removes the ability of the covers to vibrate/flex and generate the noise.....but the underlying cause is still there!  Has any one ever eliminated the noise by replacing the alt or alt dampener or anything else.
valkmc
Idaho??
Ocala/Daytona Fl
« Reply #5 on: September 27, 2010, 01:44:33 PM »
I had a noise and lived with it until my plastic cover started to peel. I think I was just use to it and did not hear it anymore. I replaced the plastic cover with a custom metal one and the noise is no longer there. The cover was made by a person on this board, however he no longer makes them.
2013 Black and Red F6B (Gone)
2016 1800 Gold Wing (Gone)
1997 Valkyrie Tourer
2018 Gold Wing Non Tour
Rio Wil
« Reply #6 on: September 27, 2010, 11:06:20 PM »
Well, maybe I should go back and revisit the cover as the issue, Thx
alph
Eau Claire, WI.
« Reply #7 on: September 28, 2010, 01:20:19 AM »
If you take the covers off, does the noise go away?  Have you tried putting a rubber washer between the mounting bolt and cover?  You can get rubber washers from the plumbing department at home depot, by the faucets.  Let us know what you find out, I’ve got kuryacan tranny covers and I haven’t ever noticed any noise.  Check to see if they’re installed correctly.
