November 21, 2025, 10:20:22 PM *
Author Topic: BROWN STUFF  (Read 1776 times)
Poor Ol Harry
Baytown,TX. East of Houston
« on: September 27, 2010, 01:41:54 PM »
Say..........when I first showed up here a year or so ago,I remember reading about some brown stuff on top of the heads & how to fix it...............well now I got it but can't find the post.Can someone please help me out?
                                                         Thanks  Harry
roboto65
Conroe,TX
« Reply #1 on: September 27, 2010, 02:05:54 PM »
Those would be bad Orings on the Intake runners replace them and the problem goes away  coolsmiley coolsmiley
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
Thunderbolt
Worthington Springs FL.
« Reply #2 on: September 27, 2010, 02:51:11 PM »
take the choke covers off,three screws on the long chrome pieces under the carb round thingies.  Then loosen the bottom bands on the rubber tubes that go from the carbs to the curved intakes on the cylinders that you suspect are leaking.  Take out the two small (8mm) bolts that secure the intakes.  Now twist a little clockwise while pulling them out.  Underneath you will find the o-ring.  Take one out and go to your supply house and get replacements.  Oh, and stuff some rags in the intake openings in the head until you are ready to reinstall everything.  Installation is the reverse.  Tighten both the top and bottom bands on the rubber tubes when you put everything back together.  They will seem tight, but you will need to break them loose, then just snug them up.
Farther
Quimper Peninsula, WA
« Reply #3 on: September 27, 2010, 04:58:42 PM »
check here before you pull it a part.  http://sites.google.com/site/valkparts/
~Farther
valkyriemc
NE Florida
« Reply #4 on: September 28, 2010, 04:20:50 AM »
http://www.valkyrieforum.com/bbs/index.php/topic,905.0.html
I just did my # 6 last week, got it from Autozone. But I dont think its Viton. See below;
http://cgi.ebay.com/ebaymotors/Intake-Runner-O-ring-Kit-Honda-Valkyrie-Viton-GF-_W0QQcmdZViewItemQQhashZitem35ab7a4dd9QQitemZ230510185945QQptZMotorcyclesQ5fPartsQ5fAccessories
Found my number 6 clamp(s) were not tight so I ended up checking, and tightning all 12. G/L.
« Last Edit: September 28, 2010, 04:23:03 AM by valkyriemc » Logged
Veteran USN '70-'76
Momz
ABATE, AMA, & MRF rep.
« Reply #5 on: September 28, 2010, 06:17:46 PM »
Yes, and don't drink too much apple cider.
It will give you BROWN STUFF where you really don't want it. Undecided
ALWAYS QUESTION AUTHORITY!
