February 01, 2026, 08:31:57 AM *
Author Topic: Hard to start  (Read 1949 times)
Troubadour
Sparta, TN
« on: October 05, 2010, 07:21:57 PM »
My 2000 Valkyrie interstate is very hard to start in mornings when temps are around 50. Any body got any ideas or tricks they use to get their Valkyrie's started when cool out? Have right around 24000 miles on it and don't know what all the original owner has done as far as engine maintenance.
Troubadour
Sparta, TN
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: October 05, 2010, 07:46:48 PM »
Probably not choking it enough. Push the choke lever until it stops, now push it another inch.
« Reply #2 on: October 06, 2010, 03:07:35 AM »
AND, before you say you already have the choke on, just go try to push it further on and try it.
Thank you, started a lot easier didn't it?
Oh yes, keep your hand off the throttle, don't mess with it till it is started and has run at least a minute....
Troubadour
Sparta, TN
« Reply #3 on: October 06, 2010, 07:53:45 AM »
Well who would have thought, there would be more choke to use, LOL. I thought you where just kidding, went out to my Dragon this morning, chilly 40 degrees, pushed choke "ALL THE WAY DOWN" hit starter, she started right up. Thanks guys,  cooldude
Troubadour
Troubadour
Sparta, TN
« Reply #4 on: October 07, 2010, 05:56:30 AM »
I think every new valk owner has had that problem, including myself, figured it out myself, was before I discovered this site.   Evil hoser
MP
North Dakota
« Reply #5 on: October 07, 2010, 12:06:00 PM »
I was lucky.  When I picked my first Valk up in South Carolina, the owner showed me how far and hard you had to push the choke.
MP
"Ridin' with Cycho"
valkyriemc
NE Florida
« Reply #6 on: October 08, 2010, 05:36:38 AM »
I think you push it down to the split on the handlebar housing. I did a search on the old board for a picture that was once taken of the choke in its full position. I  found the post among several hundred(?) on the subject but only the dreaded "red X" was there.
Veteran USN '70-'76
« Reply #7 on: October 08, 2010, 07:29:03 AM »
You can look down, on the right side, just at the end of the chrome cover that hides the mechanism of the choke apparatus and watch for movement of the bar that controls all three of the enrichment valves.
It will not move until pressure is applied at the handlebars. Meaning: no "choke".
Doc X
« Reply #8 on: October 09, 2010, 08:19:42 AM »
I have a 2000 I/S which was hard to start when it is in the 50* range.  I put NKG iridium plugs in two week ago and she is no longer hard to start, she fires right up.
I don't know what plugs you have in your bike, but the NKG iridium plugs solved the problem for me! I have used gallons of Tectron and Gum Out but the Plug change is what cured the problem. Of course each bike is a law unto themselves, so I don't know if it will solve your hard start problem.
Doc X
