February 01, 2026, 08:32:56 AM *
Author Topic: whiney, shrilley noise...new to me  (Read 1964 times)
bg
Cumming, Ga
« on: October 06, 2010, 11:45:35 AM »
i hear this noise when going up hill (not even a steep one) and the throttle under pressure.
when i left off the throttle the whiney shrilley thingey noise stops.
this just started and i have no idea what it is.
any ideas?????????
Redline +
Northwest Washington
« Reply #1 on: October 06, 2010, 11:52:53 AM »
I had a noise like that...now my wife rides her own bike...problem solved. Grin
Redline  Cool
« Reply #2 on: October 06, 2010, 12:03:08 PM »
Kind of sounds like the big long bolt at the front of the motor that goes all the way across.
Have someone hold one side and you hit the other side with a good impact wrench.
Solved my problem.....
Thunderbolt
Worthington Springs FL.
« Reply #3 on: October 06, 2010, 04:53:37 PM »
check behind the intake where the vacuum lines attach.  If your bike is stock there will be a vacuum line on #3,#4, and #6.  The others will have caps.  The most common problem is that the lines get soft and mushy near the attachment point on the back of the intakes and will split, that causes a shrill whistling noise.
« Reply #4 on: October 10, 2010, 08:44:15 AM »
If the sound is around 50-55mph its probably the square cut gears our bikes have.....they all whine a bit at that speed.......I didnt notice it until I put a windshield on now I am used ot it and dont really hear it unless I try to
sugerbear
wentzville mo
« Reply #5 on: October 13, 2010, 05:49:51 PM »
soooooooooooooooooo redline, does your head resemble the shape of a skillet?? angel
Redline +
« Reply #6 on: October 13, 2010, 08:33:28 PM »
10" castiron...but only on one side. crazy2
Redline  Cool
