February 01, 2026, 08:32:05 AM *
Author Topic: Question regarding Jardine exhaust  (Read 1824 times)
Grandpa Bigbuck
Paola, KS
« on: October 13, 2010, 05:58:05 PM »
My wifes Valkyrie trike has Jardine exhaust with no baffles.  Finally found some baffles but have no idea on how to mount them.  If anyone has any input it would be appreciated. Thanks
« Reply #1 on: October 13, 2010, 10:49:01 PM »
Most baffles slide up the exhaust pipe and have a bolt,(cap screw) that holds them in place.......
aslondon
VRCC #4321
Monticello, Fl
« Reply #2 on: October 14, 2010, 04:45:31 AM »
If they are the "Rumblers" which end about under the rear axle then look for I think 2 or maybe 3 small holes a couple of inches in from the end where the baffles were riveted in place.  I have a set on my bike so if you have any questions let me know
Al
VRCC 4321
Grandpa Bigbuck
Paola, KS
« Reply #3 on: October 14, 2010, 05:25:30 PM »
Al
VRCC 4321
Thanks Al.  I'm assuming that the cone shaped end goes in first and the square cut end is in the back, and I need to drill through the flange on the square cut end and use pop rivets to attach to the exhaust.  Is this correct?
Dave
