May 02, 2026, 10:39:24 PM
Texas Chapter
(Moderator:
Daniel Meyer
fuel problem
Topic: fuel problem (Read 1352 times)
oldman
Texarkana, Tx
fuel problem
October 17, 2010, 11:39:14 PM »
One of the guys in our group had one of his carbs leak gas into the cyclinders and cause it to lock up and not start. We've pulled the carbs and are cleaning them and replaceing the needle seats (float valves) my question, is there any thing else that can cause the cyclinder to flood besides the needle seat not sealing??? Any thoughts would be appreciated, thanks
Oldman
Persevere to endure
f-Stop
'98 Standard named Hildr
Driftwood, Texas
Re: fuel problem
October 18, 2010, 05:49:31 AM »
The fuel valve needs to be replaced on the petcock. It is referred to as the "Cover Set". The valve should not let fuel flow without vacuum from the #6 intake manifold...no matter what position the fuel cut off valve is in.
Here's Dag's info on that:
http://www.valkyrienorway.com/partspetcock.html
About $29 (#5) from Honda Direct Line:
http://www.hdlparts.com/fiche_section_detail.asp?section=148103&category=MOTORCYCLES&make=HONDA&year=1998&fveh=3466
Good Luck!
Ghillie
Garland, TX
Re: fuel problem
October 18, 2010, 07:26:25 AM »
search hydrolock in the tech archives, tons of info
When the people fear government, there is tyranny. When government fears the people, there is liberty.
