January 28, 2026, 09:53:37 AM *
Author Topic: GOT A LOUD TICKING......need advice  (Read 3811 times)
bigvalkriefan
On the green monster
South Florida
« on: March 30, 2009, 07:24:41 PM »
OK, I did a des-mog, installed an electric fuel valve, reset the needles to the second slot from the top, flushed the tank,replaced the petcock vacuum line and installed a new to me stock exhaust system. After crossing my fingers when I went to start it she fired right up. Here's the problem, I now have a loud tick on the right side. I never heard the sound before this although I did have supertrapps that were kind of loud but not that loud. Could a tick be an exhaust leak? I don't think it's valves because I never heard it before. I did not install new gaskets yet, I'm waiting on them. Any thoughts?
.....say to those with fearful hearts, "Be strong, do not fear; your God will come, he will come with vengeance; with divine retribution he will come to save you."
Isaiah 35:4
I know who wins in the end.
DFragn
« Reply #1 on: March 30, 2009, 08:20:30 PM »
Yea it very well could be an exhaust gasket leak. Try rehanging the right side exhaust while shoring the headers evenly and flush to the gaskets.
valk2128
Suwanee, GA
« Reply #2 on: March 31, 2009, 02:01:29 AM »
I had a loud ticking after I de-smogged, it ws the air - input that I had sealed under the exhaust.   When they leak you will get the loud ticking.  Had to take it back off and put a new gasket in.
Also did you replace the gaskets on the exhuast?  This should be done everytime the exhaust is taken off and reinstalled.  Torque the exhaust header bolts to 7 foot lbs.
Good luck.
bigvalkriefan
South Florida
« Reply #3 on: March 31, 2009, 03:20:52 AM »
I will remove the exhaust and reseal the air input while the exhaust is off, tonight. If that doesn't do it the I will check the valves.
Thanks!
Isaiah 35:4
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #4 on: March 31, 2009, 04:05:34 AM »
I had the same problem when I did those maintenance mods. I agree with DFragn and Valk2128. Did you replace your gaskets? Torque 7lbs, start from middle work your way out. Mine sounded pretty bad, mechanical. It was just an exhaust leak. Good luck cooldude
LL
Flower Mound TEXAS!!!!!!
« Reply #5 on: March 31, 2009, 05:07:46 AM »
Don't forget about the intake O-rings, cheap and easy to replace. How do I know?...............
VRCC #472
