February 01, 2026, 10:00:35 AM
Progressive springs - couple of questions
Topic: Progressive springs - couple of questions (Read 1850 times)
Tx Bohemian
Victoria, Tx
October 18, 2010, 02:37:07 PM »
From what I've read here progressive springs are better than the stock springs.
Is there anyway to tell a progressive spring from a stock spring? Would there be a marking on either? (stamp, tag, etc...) Or could I tell by the length or thickness?
I have a set of used forks I'm going to reseal and install on my bike and would like to determine if it has progressive springs in them or not.
Al
Re: Progressive springs - couple of questions
October 18, 2010, 05:36:26 PM »
Progressives are shorter than stock but the ride height is the same due to the stiffness.
Anthony
Belgium
October 19, 2010, 03:56:16 AM »
you can tell by looking at 1 spring :
OEM Honda fork springs are wound the same all over its length,
progressive fork springs are wound thighter on the one end then the other, thus being a 'progressive' spring.
To compress it 2 inch, it takes more then 2 x the force to compress it 1 inch.
Anthony
Tx Bohemian
Victoria, Tx
October 20, 2010, 05:50:18 AM »
Thanks fellas
Al
