February 01, 2026, 10:00:34 AM *
Author Topic: Duece risers installed now cables bind at RH lock.  (Read 1926 times)
Tropic traveler
Silver Springs, Florida
« on: October 18, 2010, 08:30:53 PM »
Really do like the position that the risers put the bars in but.... after relocating the throttle cables behind the tree it binds at RH lock. Gets worse as the bars turn right until a total bind at lock. Seems the forks smash the cables putting them in a kink where they go under the black cover. If the cables were 3" or so longer I could route them back in front of the bars where they should go eliminating the smash.
All this leads me to the question, where to get 3" longer throttle cables for the Valk? HDL, BikeBandit don't list anything other than stock length replacements. I don't want to ride it like it is.
Anybody know??
'13 F6B red for Kim
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #1 on: October 18, 2010, 09:39:18 PM »
contac daryl at xf6-custom.com  he either has, or can get them for you.
« Reply #2 on: October 19, 2010, 03:20:06 AM »
Eddie, I got mine at Barnett a few years back, plus had them change the top end to work on my HD controls. Wish I'd known when we were in Daytona Sat., I'd have warned you ahead of time. Been there, done that...got rid of the risers, too high and too far back for me. See link below for Motion Pro, also make custom lengths.
http://www.motionpro.com/motorcycle/custom/
Warlock
Magnolia, Ms
« Reply #3 on: October 19, 2010, 05:59:15 AM »
Anybody know??
I got mine at motion pro. You only needs them 2" longer than stock. I ordered mine 3" longer and they work well, but wished I had ordered them 2" longer. I called them and told them I needed some and they made them for me.
David
Tropic traveler
« Reply #4 on: October 19, 2010, 06:36:33 PM »
Dang if you weren't right John. The new risers felt real nice sittin' on it in the garage! Took it out for a spin this evening before I started calling around for cables & just like you said, too high. The pullback is OK but they are going to have to go. I have the Lamonster risers on my '97 & I suspect that is what I need for my '99.
Oh well, nothing ventured, nothing gained.
Special thanks to DD!! I have modified the Duece risers to fit a Valk now so if you want them back lemme know!
'13 F6B red for Kim
« Reply #5 on: October 19, 2010, 07:21:43 PM »
Motion pro, i'd do bussiness with them again. Great customer service.  cooldude
Thunderbolt
Worthington Springs FL.
« Reply #6 on: October 20, 2010, 05:52:27 PM »
helped a lot for both of us.  Not too expensive and no new cables needed, just reroute the ole ones.
