February 01, 2026, 11:34:54 AM *
Author Topic: removing seat lock panel  (Read 1972 times)
Alaskamike
gittin her done!
Wasilla, Alaska
« on: October 19, 2010, 02:35:27 PM »
I am repainting the Beast and trying to remove the plastic panel where the seat lock is located.  It appears there is a sensor attached and I see how to remove that, but the mechanism behind the lock is giving me fits  tickedoff.  It is a 97 Tourer.
Any suggestions on how to get the cable off?  Am I just brain dead?  I don't want to break anything if I can help it.
Thanks.
BTW, once this is out is there any maintenance I might do tot he seat lock assembly to make it work better while I'm at it?
"If you don't ride in the rain.... you don't ride"
« Reply #1 on: October 19, 2010, 02:38:21 PM »
you just have to pull the clip off that is inside.  it simply slides off thereby allowing the lock to be removed
Alaskamike
gittin her done!
Wasilla, Alaska
« Reply #2 on: October 19, 2010, 03:54:28 PM »
thanks, I did get that black clip off, no problem.  But the lock is held in with the seat lock cable.  Do I just pry the cable off the white plastic thing holding it?
Also, the manuel says to disonecet the bank - angle sensor 3 in white electrical connector.  Okay, so I exposed it, and can't seem to see how it comes apart.    I don't want to pull on it too hard and pull the wires loose.  It almost seems like a single piece but I know it comes apart somehow.
Alaskamike
gittin her done!
Wasilla, Alaska
« Reply #3 on: October 19, 2010, 04:02:36 PM »
...... I should say, I am a novice (who would'a guessed  Cheesy)  at mechanics, but am trying to learn, unfortunatly where I live there is not much help.......
ricoman
Sarasota, FL
« Reply #4 on: October 19, 2010, 04:44:28 PM »
check a parts fiche, sometimes the exploded picture will give you an insight to nuts, bolts and other connectors to undo
Valkpilot
What does the data say?
Corinth, Texas
« Reply #5 on: October 19, 2010, 05:02:55 PM »
Refer to this fische: http://www.hdlparts.com/fiche_section_detail.asp?section=148817&category=MOTORCYCLES&make=HONDA&year=1998&fveh=3477
Once you pull the sliding clip that holds the lock in place (part #1), you can push the lock out and rotate it so that the cable slips easily out of its stay.
Refer to this fische: http://www.hdlparts.com/fiche_section_detail.asp?section=148830&category=MOTORCYCLES&make=HONDA&year=1998&fveh=3477
I find that once this is done, it is easier to unscrew the bank angle sensor (part #8) from the center panel rather than unclip the connector.  Just don't reinstall it upside down!
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Alaskamike
gittin her done!
Wasilla, Alaska
« Reply #6 on: October 19, 2010, 06:00:56 PM »
Thanks guys - got it out!  Funny how simple looking things can thow me a loop.  No wonder mechanics make the big bucks  Wink
Having this board gives me courage to do things I might not try; So far got new rear tire (Avon Venom),  bel-ray in splines and new O rings (including elusive 3rd ring, new rear brakes, new plugs and wires, progressive rear shocks, Rivco air horn, velocity stacks in place.   Next comes 3 motosens guages, Interstate tank as well as belly tank, PIAA added lights, Ultimate seats, carb cleaning and sync (I'm having a mechanic do this one)and New paint (Black ...with graphics, of course)  so far.... so good!
I'll post pics when I'm done.  Got all winter here in Alaska.
« Reply #7 on: October 19, 2010, 07:51:01 PM »
Oh c'mon.........you dont ride just because it gets a little cold......hehehe  (kidding)  I been to Arctic Survival School..........good luck with the work!
Alaskamike
gittin her done!
Wasilla, Alaska
« Reply #8 on: October 19, 2010, 08:45:23 PM »
it'll be in the March cycle show at the Eagan Center........... if you're up Alaska way!
